[GRASS-dev] [GRASS-SVN] r68180 - grass/trunk/lib/python/script
Ciao,
2016-03-29 8:29 GMT+02:00 <svn_grass@osgeo.org>:
Author: zarch
Date: 2016-03-28 23:29:14 -0700 (Mon, 28 Mar 2016)
New Revision: 68180
Modified:
   grass/trunk/lib/python/script/utils.py
Log:
script.utils: fix bug in decode/encode function
candidate for backport? Ma
Modified: grass/trunk/lib/python/script/utils.py
--- grass/trunk/lib/python/script/utils.py 2016-03-29 06:24:03 UTC (rev 68179)
+++ grass/trunk/lib/python/script/utils.py 2016-03-29 06:29:14 UTC (rev 68180)
@@ -156,10 +156,8 @@
     :param str string: the string to decode
     enc = locale.getdefaultlocale()[1]
- if enc:
- if hasattr(string, 'decode'):
- return string.decode(enc)
+ if hasattr(string, 'decode'):
+ return string.decode(enc) if enc else string.decode()
     return string
@@ -169,10 +167,8 @@
     :param str string: the string to encode
- if enc:
- if hasattr(string, 'encode'):
- return string.encode(enc)
+ if hasattr(string, 'encode'):
+ return string.encode(enc) if enc else string.encode()
     return string
@@ -376,5 +372,5 @@
             pathname = os.path.join(modulename, dirname) if dirname else modulename
             raise ImportError("Not able to find the path '%s' directory "
                               "(current dir '%s')." % (pathname, os.getcwd()))
         sys.path.insert(0, path)
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Hi Martin,
On Tue, Mar 29, 2016 at 9:16 AM, Martin Landa <landa.martin@gmail.com> wrote:
Yes, I think this could be backported with no problems.
Current implementation is not working when for example the LC_ALL=C,
see tests in r68179.
All the best.
Pietro
