[GRASS-dev] [GRASS-SVN] r69651 - grass/trunk/vector/v.external
Hi Martin,
regarding r69651, would you consider moving the code to a function in a
separate file or preferable putting it to the library? There is several
modules which have similar code.
Vaclav
On Mon, Oct 3, 2016 at 11:47 AM, <svn_grass@osgeo.org> wrote:
Author: martinl
Date: 2016-10-03 08:47:30 -0700 (Mon, 03 Oct 2016)
New Revision: 69651
Added:
   grass/trunk/vector/v.external/proj.c
Modified:
   grass/trunk/vector/v.external/local_proto.h
   grass/trunk/vector/v.external/main.c
Log:
v.external: fix check projection
2016-10-03 19:00 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
the code has been already moved to a function - check_projection() in
a separate file (proj.c).
Yes, long-term wish, there should be already ticket reported. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
