[GRASS-dev] [GRASS-SVN] r70710 - in grass/branches/releasebranch_7_2: lib/vector/vedit raster/r.timestamp raster/r.to.vect raster/r.topidx raster/r.topmodel scripts/v.db.addtable vector/v.build.polylines vector/v.distance vector/v.edit vector/v.patch
please *explain* your changes in log message next time. It's
flustrating for those who are preparing news page about release to dig
into such commits. Log message should help to understand what is
purpose of the commit.
Thanks for taking care about backports. Ma
2017-03-01 12:45 GMT+01:00 <svn_grass@osgeo.org>:
Author: hcho
Date: 2017-03-01 03:45:44 -0800 (Wed, 01 Mar 2017)
New Revision: 70710
Added:
   grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c
Modified:
   grass/branches/releasebranch_7_2/lib/vector/vedit/break.c
   grass/branches/releasebranch_7_2/lib/vector/vedit/move.c
   grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c
   grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html
   grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c
   grass/branches/releasebranch_7_2/raster/r.to.vect/global.h
   grass/branches/releasebranch_7_2/raster/r.to.vect/main.c
   grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html
   grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html
   grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py
   grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c
   grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c
   grass/branches/releasebranch_7_2/vector/v.distance/main.c
   grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html
   grass/branches/releasebranch_7_2/vector/v.edit/main.c
   grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c
   grass/branches/releasebranch_7_2/vector/v.patch/main.c
   grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c
   grass/branches/releasebranch_7_2/vector/v.select/main.c
   grass/branches/releasebranch_7_2/vector/v.to.db/main.c
   grass/branches/releasebranch_7_2/vector/v.to.points/write.c
   grass/branches/releasebranch_7_2/vector/v.what/main.c
Log:
Backport r70666, r70637, r70636, r70635, r70634, r70633, r70706, r70707, r70708, r70611, r70612, r70613, r70614, r70599, r70589, r70586, r70582, r70537, r70509, r70506, r70709, r70507, r69139
Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/break.c
--- grass/branches/releasebranch_7_2/lib/vector/vedit/break.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/lib/vector/vedit/break.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -247,12 +247,13 @@
        line_new = -1;
     if (line_new > -1) {
+ n_points = Points_from->n_points - 1;
        if (first) {
            x = Points_from->x[0];
            y = Points_from->y[0];
        else {
- n_points = Points_from->n_points - 1;
            x = Points_from->x[n_points];
            y = Points_from->y[n_points];
Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/move.c
--- grass/branches/releasebranch_7_2/lib/vector/vedit/move.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/lib/vector/vedit/move.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -71,7 +71,7 @@
                    for (bgi = 0; bgi < nbgmaps; bgi++) {
                        if (Vedit_snap_point
- (BgMap[bgi], line, &x[j], &y[j], &z[j], thresh,
+ (BgMap[bgi], -1, &x[j], &y[j], &z[j], thresh,
                             (snap == SNAPVERTEX) ? 1 : 0))
                            break; /* snapped, don't continue */
Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c
--- grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -115,7 +115,7 @@
- (BgMap[bgi], line, &x[k], &y[k],
+ (BgMap[bgi], -1, &x[k], &y[k],
                                         &z[k], thresh_snap,
                                        moved[k] = 2;
Modified: grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html
--- grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html 2017-03-01 11:45:44 UTC (rev 70710)
@@ -15,7 +15,7 @@
The timestamp values must use the format as described in the <em>GRASS
Datetime Library</em>. The source tree for this library should have a
-description of the format. For convience, the formats are reproduced
+description of the format. For convenience, the formats are reproduced
here:
<p>There are two types of datetime values:
Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c
--- grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -34,7 +34,7 @@
int write_boundary(struct COOR *seed)
     struct COOR *point, *line_begin, *line_end, *last;
- int dir, line_type, n, n1, i;
+ int dir, line_type, n, n1;
     point = seed;
     if ((dir = at_end(point))) { /* already have one end of line */
Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/global.h
--- grass/branches/releasebranch_7_2/raster/r.to.vect/global.h 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.to.vect/global.h 2017-03-01 11:45:44 UTC (rev 70710)
@@ -104,7 +104,7 @@
int extract_lines(void);
/* lines_io.c */
-int write_line(struct COOR *seed);
+int write_line(struct COOR *);
/* areas.c */
int alloc_areas_bufs(int);
@@ -112,7 +112,7 @@
int more_equivs(void);
/* areas_io.c */
-int write_boundary(struct COOR *seed);
+int write_boundary(struct COOR *);
int write_area(struct area_table *, struct equiv_table *, int, int);
/* points.c */
@@ -124,4 +124,7 @@
int at_end(struct COOR *);
int read_row(void *);
void insert_value(int, int, double);
-int free_ptr(struct COOR *ptr);
+int free_ptr(struct COOR *);
+/* set_error_handler.c */
+void set_error_handler(struct Map_info *, dbDriver **);
Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/main.c
--- grass/branches/releasebranch_7_2/raster/r.to.vect/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.to.vect/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -8,7 +8,7 @@
  * PURPOSE: Converts a raster map into a vector map layer
- * COPYRIGHT: (C) 2007, 2011 by the GRASS Development Team
+ * COPYRIGHT: (C) 2007, 2011, 2017 by the GRASS Development Team
  * This program is free software under the GNU General Public
  * License (>=v2). Read the file COPYING that comes with GRASS
@@ -151,10 +151,11 @@
        G_warning(_("Categories will be unique sequence, raster values will be lost."));
+ set_error_handler(&Map, &driver);
     if (Vect_open_new(&Map, out_opt->answer, z_flg->answer) < 0)
        G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
- Vect_set_error_handler_io(NULL, &Map);
     Vect_hist_command(&Map);
     Cats = Vect_new_cats_struct();
@@ -186,7 +187,6 @@
        if (driver == NULL)
            G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
                          Fi->database, Fi->driver);
- db_set_error_handler_driver(driver);
        /* Create new table */
        db_zero_string(&sql);
Added: grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c
--- grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c (rev 0)
+++ grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -0,0 +1,33 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+struct handler_input
+ struct Map_info *Map;
+ dbDriver **driver;
+static void error_handler(void *p)
+ const struct handler_input *input = (const struct handler_input *)p;
+ if (input->driver && *input->driver)
+ db_close_database_shutdown_driver(*input->driver);
+ if (input->Map) {
+ char *name = G_store(input->Map->name);
+ if (input->Map->open == VECT_OPEN_CODE)
+ Vect_close(input->Map);
+ Vect_delete(name);
+ G_free(name);
+void set_error_handler(struct Map_info *Map, dbDriver **driver)
+ struct handler_input *input = G_malloc(sizeof(struct handler_input));
+ input->Map = Map;
+ input->driver = driver;
+ G_add_error_handler(error_handler, input);
Modified: grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html
--- grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html 2017-03-01 11:45:44 UTC (rev 70710)
@@ -23,7 +23,7 @@
<a href="r.mapcalc.html">r.mapcalc</a>
</em>
<br>
-<a href="http://idea.isnew.info/r.topidx&quot;&gt;Known issues</a>
+<a href="http://idea.isnew.info/r.topidx.html&quot;&gt;Known issues</a>
<h2>REFERENCES</h2>
Modified: grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html
--- grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html 2017-03-01 11:45:44 UTC (rev 70710)
@@ -152,7 +152,7 @@
<a href="r.topidx.html">r.topidx</a>
</em>
<br>
-<a href="http://idea.isnew.info/r.topmodel&quot;&gt;How to run r.topmodel</a>
+<a href="http://idea.isnew.info/r.topmodel.html&quot;&gt;How to run r.topmodel</a>
<h2>AUTHORS</h2>
Modified: grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py
--- grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py 2017-03-01 11:45:44 UTC (rev 70710)
@@ -86,7 +86,7 @@
         grass.verbose(_("Using user specified table name: %s") % table)
     # check if DB parameters are set, and if not set them.
- grass.run_command('db.connect', flags='c')
+ grass.run_command('db.connect', flags='c', quiet=True)
     grass.verbose(_("Creating new DB connection based on default mapset settings..."))
     kv = grass.db_connection()
     database = kv['database']
@@ -106,15 +106,21 @@
                                 stderr=nuldev)
     if not table in tables.splitlines():
+ colnames =
         if columns:
- column_def = [x.strip().lower() for x in columns.strip().split(',')]
+ column_def =
+ for x in ' '.join(columns.lower().split()).split(','):
+ colname = x.split()[0]
+ if colname in colnames:
+ grass.fatal(_("Duplicate column name '%s' not allowed") % colname)
+ colnames.append(colname)
+ column_def.append(x)
         else:
             column_def =
         # if not existing, create it:
- column_def_key = "%s integer" % key
- if column_def_key not in column_def:
- column_def.insert(0, column_def_key)
+ if not key in colnames:
+ column_def.insert(0, "%s integer" % key)
         column_def = ','.join(column_def)
         grass.verbose(_("Creating table with columns (%s)...") % column_def)
@@ -133,10 +139,17 @@
                       map=map_name, database=database, driver=driver,
                       layer=layer, table=table, key=key)
- # finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
- # (creates new row for each vector line):
- grass.run_command('v.to.db', map=map_name, layer=layer,
- option='cat', column=key, qlayer=layer)
+ # finally we have to add cats into the attribute DB to make
+ # modules such as v.what.rast happy: (creates new row for each
+ # vector line):
+ try:
+ grass.run_command('v.to.db', map=map_name, layer=layer,
+ option='cat', column=key, qlayer=layer)
+ except CalledModuleError:
+ # remove link
+ grass.run_command('v.db.connect', quiet=True, flags='d',
+ map=map_name, layer=layer)
+ return 1
     grass.verbose(_("Current attribute table links:"))
     if grass.verbosity() > 2:
Modified: grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c
--- grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -97,7 +97,6 @@
     int polyline;
     int *lines_visited;
- int points_in_polyline;
     int start_line;
     int nlines;
     int write_cats, copy_tables;
@@ -177,8 +176,10 @@
        write_cats = NO_CATS;
     else if (strcmp(cats->answer, "first") == 0)
        write_cats = ONE_CAT;
- else
+ else if (strcmp(cats->answer, "multi") == 0)
        write_cats = MULTI_CATS;
+ else
+ write_cats = SAME_CATS;
     if (type_opt->answer)
        type = Vect_option_to_types(type_opt);
@@ -218,9 +219,8 @@
        G_debug(1, "Polyline %d: start line = %d", polyline, start_line);
        /* Walk forward and pick up coordinates */
- points_in_polyline =
- walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
- lines_visited, Cats, write_cats);
+ walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
+ lines_visited, Cats, write_cats);
        /* Write the line (type of the first line is used) */
        Vect_write_line(&Out, ltype, points, Cats);
@@ -230,12 +230,10 @@
     G_verbose_message(n_("%d line or boundaries found in input vector map",
                          "%d lines or boundaries found in input vector map",
- nlines),
- nlines, Vect_get_name(&map), Vect_get_mapset(&map));
+ nlines), nlines);
     G_verbose_message(n_("%d polyline stored in output vector map",
                          "%d polylines stored in output vector map",
- polyline),
- polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
+ polyline), polyline);
     /* Copy (all linked) tables if needed */
     if (copy_tables) {
Modified: grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c
--- grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -129,7 +129,7 @@
     int cat_idx;
     int line, next_line, n1, n2;
- int type, node, next_node;
+ int node, next_node;
     struct line_pnts *pnts;
     struct line_cats *cats_tmp;
@@ -149,9 +149,9 @@
     /* Pick up first set of coordinates */
     lines_visited[line] = 1;
     if (cats_tmp)
- type = Vect_read_line(map, pnts, Cats, line);
+ Vect_read_line(map, pnts, Cats, line);
     else
- type = Vect_read_line(map, pnts, NULL, line);
+ Vect_read_line(map, pnts, NULL, line);
     Vect_get_line_nodes(map, line, &n1, &n2);
     next_line = find_next_line(map, line, n1, ltype);
@@ -175,7 +175,7 @@
     node = next_node;
     while (line != 0 && line != start_line) {
        G_debug(2, " line = %d", line);
- type = Vect_read_line(map, pnts, cats_tmp, line);
+ Vect_read_line(map, pnts, cats_tmp, line);
        if (cats_tmp && write_cats == MULTI_CATS) {
            for (cat_idx = 0; cat_idx < cats_tmp->n_cats; cat_idx++) {
                Vect_cat_set(Cats, cats_tmp->field[cat_idx],
Modified: grass/branches/releasebranch_7_2/vector/v.distance/main.c
--- grass/branches/releasebranch_7_2/vector/v.distance/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.distance/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -286,6 +286,10 @@
            Upload[i].upload = TO_ATTR;
+ /* store default column names if column= is not given */
+ if (!opt.column->answer)
+ Upload[i].column = G_store(opt.upload->answers[i]);
        i++;
     Upload[i].upload = END;
@@ -625,8 +629,12 @@
     /* Go through all lines in 'from' and find nearest in 'to' for each */
- /* Note: as from_type is restricted to GV_POINTS (for now) everything is simple */
+ /* Note: as from_type is restricted to GV_POINTS (for now) everything is
+ * simple */
+ /* suppress compiler warnings */
+ tx = ty = tz = fx = fy = fz = 0;
     count = 0; /* count of distances in 'do_all' mode */
     /* Find nearest features for 'from' lines */
     if (nfromlines) {
@@ -1388,7 +1396,7 @@
            G_percent(i, count, 1);
        /* Write line connecting nearest points */
- if (Outp != NULL) {
+ if (Near[i].count > 0 && Outp != NULL) {
            Vect_reset_line(FPoints);
            Vect_reset_cats(FCats);
Modified: grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html
--- grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html 2017-03-01 11:45:44 UTC (rev 70710)
@@ -97,7 +97,7 @@
needed for network analysis:
<div class="code"><pre>
-v.distance -p from=pnt to=ln out=connections upload=dist column=dist
+v.distance from=pnt to=ln out=connections upload=dist column=dist
</pre></div>
<h3>Query information</h3>
@@ -116,7 +116,7 @@
Find nearest features:
-v.distance from=pnt to=map_to_query upload=cat col=somecol -p
+v.distance -p from=pnt to=map_to_query upload=cat
</pre></div>
<h3>Point-in-polygon</h3>
@@ -174,7 +174,7 @@
echo "0|-58|1" | v.in.ascii output=pnt2 input=-
# here, distances is in degree units
-v.distance from=pnt1 to=pnt2 upload=dist col=distance -p --q
+v.distance -p --q from=pnt1 to=pnt2 upload=dist
from_cat|distance
1|3
</pre></div>
@@ -186,15 +186,14 @@
<p>
Spearfish sample data location:
-v.distance -pa from=archsites to=archsites upload=dist col=dist
+v.distance -pa from=archsites to=archsites upload=dist
</pre></div>
<p>
North Carolina sample data location:
-v.distance -pa from=hospitals to=hospitals upload=dist \
- col=dist separator=comma
+v.distance -pa from=hospitals to=hospitals upload=dist separator=tab
from_cat to_cat dist
               1 2 3 4 5 ...
1 0 7489.10 339112.17 70900.39 70406.23 ...
Modified: grass/branches/releasebranch_7_2/vector/v.edit/main.c
--- grass/branches/releasebranch_7_2/vector/v.edit/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.edit/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -8,7 +8,7 @@
  * Jachym Cepicky
  * Major updates by Martin Landa <landa.martin gmail.com>
- * COPYRIGHT: (C) 2006-2014 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2017 by the GRASS Development Team
  * Public License (>=v2). Read the file COPYING that comes
Modified: grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c
--- grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -39,6 +39,8 @@
     if (maxdistance < 0.0) {
        G_get_window(&window);
+ G_begin_distance_calculations();
        ew_dist1 =
            G_distance(window.east, window.north, window.west, window.north);
        /* EW Dist at South Edge */
Modified: grass/branches/releasebranch_7_2/vector/v.patch/main.c
--- grass/branches/releasebranch_7_2/vector/v.patch/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.patch/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -413,8 +413,11 @@
     Vect_set_map_name(&OutMap, "Output from v.patch");
     Vect_set_person(&OutMap, G_whoami());
- if (!no_topo->answer)
+ if (!no_topo->answer) {
+ if (append->answer)
+ Vect_build_partial(&OutMap, GV_BUILD_NONE);
        Vect_build(&OutMap);
     Vect_close(&OutMap);
     if (bbox_name) {
Modified: grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c
--- grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -55,12 +55,17 @@
        OFi =
            Vect_default_field_info(Out, IFi->number, IFi->name, ttype);
- ret =
- db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
- OFi->driver,
- Vect_subst_var(OFi->database, Out),
- OFi->table, IFi->key, cats[i],
- ncats[i]);
+ if (ncats[i] > 0)
+ ret = db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
+ OFi->driver,
+ Vect_subst_var(OFi->database, Out),
+ OFi->table, IFi->key, cats[i],
+ ncats[i]);
+ else
+ ret = db_copy_table_where(IFi->driver, IFi->database, IFi->table,
+ OFi->driver,
+ OFi->table, "0 = 1");
        if (ret == DB_FAILED) {
            G_warning(_("Unable to copy table for layer %d"), fields[i]);
Modified: grass/branches/releasebranch_7_2/vector/v.select/main.c
--- grass/branches/releasebranch_7_2/vector/v.select/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.select/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -7,7 +7,7 @@
  * Markus Neteler <neteler itc.it>
  * Martin Landa <landa.martin gmail.com> (GEOS support)
  * PURPOSE: Select features from one map by features in another map.
- * COPYRIGHT: (C) 2003-2014 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2017 by the GRASS Development Team
Modified: grass/branches/releasebranch_7_2/vector/v.to.db/main.c
--- grass/branches/releasebranch_7_2/vector/v.to.db/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.to.db/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -68,7 +68,7 @@
     /* allocate array for values */
- /* (+ 1 is for cat -1 (no category) reported at the end ) */
+ /* (+1 is for cat -1 (no category) reported at the end ) */
     findex = Vect_cidx_get_field_index(&Map, options.field);
     if (findex > -1) {
        n = Vect_cidx_get_num_unique_cats_by_index(&Map, findex);
@@ -80,7 +80,8 @@
     Values = (struct value *) G_calloc(n + 1, sizeof(struct value));
     /* prepopulate Values */
- n = Vect_cidx_get_num_cats_by_index(&Map, findex);
+ if (findex > -1)
+ n = Vect_cidx_get_num_cats_by_index(&Map, findex);
     i = 0;
     Values[i].cat = -1; /* features without category */
     Values[i].used = 0;
Modified: grass/branches/releasebranch_7_2/vector/v.to.points/write.c
--- grass/branches/releasebranch_7_2/vector/v.to.points/write.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.to.points/write.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -84,7 +84,7 @@
                len = hypot(hypot(dx, dy), dz);
                /* interpolate segment */
- if (interpolate && vert < (LPoints->n_points - 1)) {
+ if (vertex == GV_VERTEX && interpolate) {
                    int i, n;
                    double x, y, z, dlen;
Modified: grass/branches/releasebranch_7_2/vector/v.what/main.c
--- grass/branches/releasebranch_7_2/vector/v.what/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.what/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -134,6 +134,7 @@
        x = window.proj;
        G_format_resolution(window.ew_res, ewres, x);
        G_format_resolution(window.ns_res, nsres, x);
        EW_DIST1 =
grass-commit mailing list
grass-commit@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
2017-03-01 13:31 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
Also spliting such huge commit into small commits would be good idea. Ma
Log:
        line_new = -1;
        if (first) {
        else {
@@ -71,7 +71,7 @@
@@ -115,7 +115,7 @@
                                         &z[k], thresh_snap,
                                        moved[k] = 2;
@@ -15,7 +15,7 @@
here:
@@ -34,7 +34,7 @@
     point = seed;
@@ -104,7 +104,7 @@
/* lines_io.c */
/* areas.c */
@@ -112,7 +112,7 @@
/* areas_io.c */
/* points.c */
@@ -124,4 +124,7 @@
@@ -8,7 +8,7 @@
@@ -186,7 +187,6 @@
        if (driver == NULL)
@@ -0,0 +1,33 @@
+ if (input->Map) {
+ G_free(name);
+ input->Map = Map;
@@ -23,7 +23,7 @@
</em>
<br>
<h2>REFERENCES</h2>
@@ -152,7 +152,7 @@
</em>
<br>
<h2>AUTHORS</h2>
@@ -86,7 +86,7 @@
                                 stderr=nuldev)
+ colnames =
         if columns:
+ column_def =
         else:
             column_def =
+ # vector line):
+ try:
+ # remove link
+ return 1
@@ -97,7 +97,6 @@
     int polyline;
     int *lines_visited;
     int start_line;
     int nlines;
- else
+ else
@@ -218,9 +219,8 @@
- nlines),
+ nlines), nlines);
- polyline),
     if (copy_tables) {
@@ -129,7 +129,7 @@
     int cat_idx;
@@ -149,9 +149,9 @@
     if (cats_tmp)
     else
@@ -175,7 +175,7 @@
     node = next_node;
        i++;
+ * simple */
     if (nfromlines) {
@@ -97,7 +97,7 @@
</pre></div>
@@ -116,7 +116,7 @@
</pre></div>
@@ -174,7 +174,7 @@
from_cat|distance
1|3
</pre></div>
<p>
</pre></div>
<p>
               1 2 3 4 5 ...
@@ -8,7 +8,7 @@
  * Jachym Cepicky
@@ -39,6 +39,8 @@
        ew_dist1 =
     if (bbox_name) {
@@ -55,12 +55,17 @@
        OFi =
- ret =
- OFi->driver,
- ncats[i]);
+ if (ncats[i] > 0)
+ OFi->driver,
+ ncats[i]);
+ else
+ OFi->driver,
@@ -7,7 +7,7 @@
@@ -68,7 +68,7 @@
     if (findex > -1) {
@@ -80,7 +80,8 @@
+ if (findex > -1)
     i = 0;
     Values[i].used = 0;
@@ -84,7 +84,7 @@
                    int i, n;
@@ -134,6 +134,7 @@
        x = window.proj;
        EW_DIST1 =
Martin Landa
Martin Landa
Ah! Sorry for the huge comment and I forgot to copy log messages. Backporting is always difficult for me :wink:
please explain your changes in log message next time. It’s
Log:
— grass/branches/releasebranch_7_2/lib/vector/vedit/break.c 2017-03-01 11:35:50 UTC (rev 70709)
line_new = -1;
  • n_points = Points_from->n_points - 1;
if (first) {
else {
— grass/branches/releasebranch_7_2/lib/vector/vedit/move.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -71,7 +71,7 @@
  • (BgMap[bgi], line, &x[j], &y[j], &z[j], thresh,
  • (BgMap[bgi], -1, &x[j], &y[j], &z[j], thresh,
    break; /* snapped, don’t continue */
— grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -115,7 +115,7 @@
  • (BgMap[bgi], line, &x[k], &y[k],
  • (BgMap[bgi], -1, &x[k], &y[k],
    &z[k], thresh_snap,
    moved[k] = 2;
— grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html 2017-03-01 11:35:50 UTC (rev 70709)
@@ -15,7 +15,7 @@
The timestamp values must use the format as described in the GRASS
Datetime Library
here:
— grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -34,7 +34,7 @@
  • int dir, line_type, n, n1, i;
  • int dir, line_type, n, n1;
point = seed;
— grass/branches/releasebranch_7_2/raster/r.to.vect/global.h 2017-03-01 11:35:50 UTC (rev 70709)
@@ -104,7 +104,7 @@
/* lines_io.c */
/* areas.c */
@@ -112,7 +112,7 @@
/* areas_io.c */
/* points.c */
@@ -124,4 +124,7 @@
+int free_ptr(struct COOR );
— grass/branches/releasebranch_7_2/raster/r.to.vect/main.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -8,7 +8,7 @@
  • PURPOSE: Converts a raster map into a vector map layer
    • COPYRIGHT: (C) 2007, 2011 by the GRASS Development Team
    • COPYRIGHT: (C) 2007, 2011, 2017 by the GRASS Development Team
  • This program is free software under the GNU General Public
  • License (>=v2). Read the file COPYING that comes with GRASS
    G_warning(_(“Categories will be unique sequence, raster values will be lost.”));
  • set_error_handler(&Map, &driver);
G_fatal_error(_(“Unable to create vector map <%s>”), out_opt->answer);
  • Vect_set_error_handler_io(NULL, &Map);
@@ -186,7 +187,6 @@
if (driver == NULL)
G_fatal_error(_(“Unable to open database <%s> by driver <%s>”),
  • db_set_error_handler_driver(driver);
— grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c (rev 0)
@@ -0,0 +1,33 @@
  • struct Map_info *Map;
  • dbDriver **driver;
  • const struct handler_input *input = (const struct handler_input *)p;
  • if (input->driver && *input->driver)
  • db_close_database_shutdown_driver(*input->driver);
  • if (input->Map) {
  • char *name = G_store(input->Map->name);
  • if (input->Map->open == VECT_OPEN_CODE)
  • Vect_close(input->Map);
  • Vect_delete(name);
  • G_free(name);
  • struct handler_input *input = G_malloc(sizeof(struct handler_input));
  • input->Map = Map;
  • input->driver = driver;
  • G_add_error_handler(error_handler, input);
— grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html 2017-03-01 11:35:50 UTC (rev 70709)
@@ -23,7 +23,7 @@
r.mapcalc
-Known issues
+Known issues
REFERENCES
— grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html 2017-03-01 11:35:50 UTC (rev 70709)
@@ -152,7 +152,7 @@
r.topidx
-How to run r.topmodel
+How to run r.topmodel
AUTHORS
— grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py 2017-03-01 11:35:50 UTC (rev 70709)
@@ -86,7 +86,7 @@
grass.verbose(_(“Using user specified table name: %s”) % table)
  • grass.run_command(‘db.connect’, flags=‘c’)
  • grass.run_command(‘db.connect’, flags=‘c’, quiet=True)
    grass.verbose(_(“Creating new DB connection based on default mapset settings…”))
    database = kv[‘database’]
    stderr=nuldev)
  • colnames =
    if columns:
  • column_def = [x.strip().lower() for x in columns.strip().split(‘,’)]
  • column_def =
  • for x in ’ ‘.join(columns.lower().split()).split(’,'):
  • colname = x.split()[0]
  • if colname in colnames:
  • grass.fatal(_(“Duplicate column name ‘%s’ not allowed”) % colname)
  • colnames.append(colname)
  • column_def.append(x)
    else:
    column_def =
  • column_def_key = “%s integer” % key
  • if column_def_key not in column_def:
  • column_def.insert(0, column_def_key)
  • if not key in colnames:
  • column_def.insert(0, “%s integer” % key)
    column_def = ‘,’.join(column_def)
grass.verbose(_(“Creating table with columns (%s)…”) % column_def)
  • finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
  • (creates new row for each vector line):
  • grass.run_command(‘v.to.db’, map=map_name, layer=layer,
  • option=‘cat’, column=key, qlayer=layer)
  • modules such as v.what.rast happy: (creates new row for each
  • vector line):
  • try:
  • except CalledModuleError:
  • remove link
  • grass.run_command(‘v.db.connect’, quiet=True, flags=‘d’,
  • map=map_name, layer=layer)
  • return 1
grass.verbose(_(“Current attribute table links:”))
— grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -97,7 +97,6 @@
int polyline;
int *lines_visited;
  • int points_in_polyline;
    int start_line;
    int nlines;
    else if (strcmp(cats->answer, “first”) == 0)
  • else
  • else if (strcmp(cats->answer, “multi”) == 0)
  • else
  • write_cats = SAME_CATS;
@@ -218,9 +219,8 @@
G_debug(1, “Polyline %d: start line = %d”, polyline, start_line);
  • points_in_polyline =
  • walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
  • lines_visited, Cats, write_cats);
G_verbose_message(n_(“%d line or boundaries found in input vector map”,
“%d lines or boundaries found in input vector map”,
  • nlines),
  • nlines, Vect_get_name(&map), Vect_get_mapset(&map));
  • nlines), nlines);
    G_verbose_message(n_(“%d polyline stored in output vector map”,
    “%d polylines stored in output vector map”,
  • polyline),
  • polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
  • polyline), polyline);
if (copy_tables) {
— grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -129,7 +129,7 @@
int cat_idx;
  • int type, node, next_node;
  • int node, next_node;
@@ -149,9 +149,9 @@
if (cats_tmp)
  • type = Vect_read_line(map, pnts, Cats, line);
  • Vect_read_line(map, pnts, Cats, line);
    else
  • type = Vect_read_line(map, pnts, NULL, line);
  • Vect_read_line(map, pnts, NULL, line);
@@ -175,7 +175,7 @@
node = next_node;
  • type = Vect_read_line(map, pnts, cats_tmp, line);
  • Vect_read_line(map, pnts, cats_tmp, line);
— grass/branches/releasebranch_7_2/vector/v.distance/main.c 2017-03-01 11:35:50 UTC (rev 70709)
  • /* store default column names if column= is not given */
  • if (!opt.column->answer)
  • Upload[i].column = G_store(opt.upload->answers[i]);
i++;
/* Go through all lines in ‘from’ and find nearest in ‘to’ for each */
  • /* Note: as from_type is restricted to GV_POINTS (for now) everything is simple */
    • simple */
  • /* suppress compiler warnings */
  • tx = ty = tz = fx = fy = fz = 0;
count = 0; /* count of distances in ‘do_all’ mode /
Find nearest features for ‘from’ lines */
if (nfromlines) {
  • if (Outp != NULL) {
  • if (Near[i].count > 0 && Outp != NULL) {
— grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html 2017-03-01 11:35:50 UTC (rev 70709)
@@ -97,7 +97,7 @@
Query information
@@ -116,7 +116,7 @@ Find nearest features:
Point-in-polygon
@@ -174,7 +174,7 @@ echo "0|-58|1" | v.in.ascii output=pnt2 input=-
from_cat|distance
1|3
1 2 3 4 5 ...
— grass/branches/releasebranch_7_2/vector/v.edit/main.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -8,7 +8,7 @@
  • Jachym Cepicky
  • Major updates by Martin Landa <landa.martin gmail.com>
    • COPYRIGHT: (C) 2006-2014 by the GRASS Development Team
    • COPYRIGHT: (C) 2006-2017 by the GRASS Development Team
  • Public License (>=v2). Read the file COPYING that comes
— grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -39,6 +39,8 @@
  • G_begin_distance_calculations();
ew_dist1 =
— grass/branches/releasebranch_7_2/vector/v.patch/main.c 2017-03-01 11:35:50 UTC (rev 70709)
Vect_set_map_name(&OutMap, “Output from v.patch”);
  • if (!no_topo->answer)
  • if (!no_topo->answer) {
  • if (append->answer)
  • Vect_build_partial(&OutMap, GV_BUILD_NONE);
if (bbox_name) {
— grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -55,12 +55,17 @@
OFi =
  • ret =
  • db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
  • OFi->driver,
  • Vect_subst_var(OFi->database, Out),
  • OFi->table, IFi->key, cats[i],
  • ncats[i]);
  • if (ncats[i] > 0)
  • ret = db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
  • OFi->driver,
  • ncats[i]);
  • else
  • ret = db_copy_table_where(IFi->driver, IFi->database, IFi->table,
  • OFi->driver,
  • OFi->table, “0 = 1”);
G_warning(_(“Unable to copy table for layer %d”), fields[i]);
— grass/branches/releasebranch_7_2/vector/v.select/main.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -7,7 +7,7 @@
  • Markus Neteler <neteler itc.it>
  • Martin Landa <landa.martin gmail.com> (GEOS support)
  • PURPOSE: Select features from one map by features in another map.
    • COPYRIGHT: (C) 2003-2014 by the GRASS Development Team
    • COPYRIGHT: (C) 2003-2017 by the GRASS Development Team
— grass/branches/releasebranch_7_2/vector/v.to.db/main.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -68,7 +68,7 @@
  • /* (+ 1 is for cat -1 (no category) reported at the end ) */
  • /* (+1 is for cat -1 (no category) reported at the end ) */
    if (findex > -1) {
    @@ -80,7 +80,8 @@
  • n = Vect_cidx_get_num_cats_by_index(&Map, findex);
  • if (findex > -1)
    i = 0;
    Values[i].used = 0;
— grass/branches/releasebranch_7_2/vector/v.to.points/write.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -84,7 +84,7 @@
  • if (interpolate && vert < (LPoints->n_points - 1)) {
  • if (vertex == GV_VERTEX && interpolate) {
    int i, n;
— grass/branches/releasebranch_7_2/vector/v.what/main.c 2017-03-01 11:35:50 UTC (rev 70709)
@@ -134,6 +134,7 @@
x = window.proj;
    EW_DIST1 =
Martin Landa
Martin Landa
I wish I could add a log message to that commit. Since I have no admin rights to SVN… hopefully, this log message will help you prepare release news (used new tools/svnlog.sh from r70714):
r.timestamp: typo in the manual (backport r70666)
v.what: Fix the default distance threshold (backport r70637)
v.patch: build topology after appending (backport r70636)
v.edit: Fix the default threshold distance (backport r70635)
v.db.addtable: Check for duplicate column names (backport r70634)
v.to.db: Don’t throw a fatal error when there are no features (backport r70633)
v.to.db: Fix r70633; Don’t throw a fatal error when there are no features (backport r70706)
v.to.db: better check for Vect_cidx_get_num_cats_by_index (backport r70707)
v.to.db: findex > -1 (backport r70708)
v.distance: Fix separator in the manual (backport r70611)
v.distance: Update the manual; column= & -p are mutually exclusive (backport r70612)
v.distance: Define default column names for -p; Suppress compiler warnings (backport r70613)
v.distance: Don’t create (0,0) points where no nearest points are found (backport r70614)
v.build.polylines: Activate the cats=same option; Remove compile warnings (backport r70599)
v.to.points: Don’t interpolate for use=node according to the manual (backport r70589)
vedit: Remove a compile warning (backport r70586)
v.select: Avoid database warnings when no features are selected and copy an empty table (backport r70582)
vedit: Fix snapping to BgMap (backport r70537)
r.to.vect: Fix a couple of compile errors/warnings (backport r70509)
r.to.vect: Call the DB error handler before the vector handler to avoid busy database warnings
Reproduce this issue in the North Carolina sample dataset:
r.to.vect input=aspect output=aspect type=line
Any unthinned input raster will produce the same issue.
(backport r70506)
Log:
line_new = -1;
if (first) {
else {
@@ -71,7 +71,7 @@
@@ -115,7 +115,7 @@
    &z[k], thresh_snap,
    moved[k] = 2;
@@ -15,7 +15,7 @@
Datetime Library
here:
@@ -34,7 +34,7 @@
point = seed;
@@ -104,7 +104,7 @@
/* lines_io.c */
/* areas.c */
@@ -112,7 +112,7 @@
/* areas_io.c */
/* points.c */
@@ -124,4 +124,7 @@
@@ -8,7 +8,7 @@
@@ -186,7 +187,6 @@
if (driver == NULL)
@@ -0,0 +1,33 @@
  • if (input->Map) {
  • G_free(name);
  • input->Map = Map;
@@ -23,7 +23,7 @@
r.mapcalc
-Known issues
+Known issues
REFERENCES
@@ -152,7 +152,7 @@
r.topidx
AUTHORS
@@ -86,7 +86,7 @@
    stderr=nuldev)
  • colnames =
    if columns:
  • column_def =
    else:
    column_def =
  • vector line):
  • try:
  • remove link
  • return 1
@@ -97,7 +97,6 @@
int polyline;
int *lines_visited;
    int start_line;
    int nlines;
  • else
  • else
@@ -218,9 +219,8 @@
  • nlines),
  • nlines), nlines);
  • polyline),
if (copy_tables) {
@@ -129,7 +129,7 @@
int cat_idx;
@@ -149,9 +149,9 @@
if (cats_tmp)
    else
@@ -175,7 +175,7 @@
node = next_node;
i++;
    • simple */
if (nfromlines) {
@@ -97,7 +97,7 @@
Query information
Point-in-polygon
from_cat|distance
1|3
1 2 3 4 5 ...
@@ -8,7 +8,7 @@
  • Jachym Cepicky
@@ -39,6 +39,8 @@
ew_dist1 =
if (bbox_name) {
@@ -55,12 +55,17 @@
OFi =
  • ret =
  • OFi->driver,
  • ncats[i]);
  • if (ncats[i] > 0)
  • OFi->driver,
  • ncats[i]);
  • else
  • OFi->driver,
@@ -7,7 +7,7 @@
@@ -68,7 +68,7 @@
    if (findex > -1) {
    @@ -80,7 +80,8 @@
  • if (findex > -1)
    i = 0;
    Values[i].used = 0;
@@ -84,7 +84,7 @@
    int i, n;
@@ -134,6 +134,7 @@
x = window.proj;
    EW_DIST1 =
Martin Landa
Martin Landa
