On Fri, Mar 31, 2017 at 8:56 AM, <svn_grass@osgeo.org> wrote:
Author: pvanbosgeo
Date: 2017-03-31 05:56:38 -0700 (Fri, 31 Mar 2017)
New Revision: 70814
Modified:
grass-addons/grass7/raster/r.vif/r.vif.html
grass-addons/grass7/raster/r.vif/r.vif.py
Log:
r.vif addon: computation of vif is now in Python, resulting in strongly
reduced computing times. There is an option to use a random subsample of
raster cells as input to further speed up the computations. There is
furthermore a 'low-memory' option (this is the old implementation which
uses r.regression.multi).
# import libraries
import os
import sys
import math
import numpy as np
-import grass.script as grass
+from scipy import stats
Hi Paulo,
it seems that the scipy is not used. I would just remove the line to make
the module work on computers without scipy, but you may be still planning
some changes, so I don't want to interfere. Please let me know.
Vaclav
Hi Vaclac, yes, you are right, a left-over from an earlier test version. I removed it, thanks!
Author: pvanbosgeo
New Revision: 70814
Modified:
Log:
r.vif addon: computation of vif is now in Python, resulting in strongly reduced computing times. There is an option to use a random subsample of raster cells as input to further speed up the computations. There is furthermore a ‘low-memory’ option (this is the old implementation which uses r.regression.multi).
import libraries
import os
import sys
import math
import numpy as np
Hi Paulo,
it seems that the scipy is not used. I would just remove the line to make the module work on computers without scipy, but you may be still planning some changes, so I don’t want to interfere. Please let me know.
Vaclav
