[GRASS-dev] [GRASS-SVN] r70821 - grass/trunk/include/Make
Hi Maris,
and, shall I backport this one?
On Sat, Apr 1, 2017 at 2:35 PM, <svn_grass@osgeo.org> wrote:
Author: marisn
Date: 2017-04-01 05:35:46 -0700 (Sat, 01 Apr 2017)
New Revision: 70821
Modified:
   grass/trunk/include/Make/Rules.make
Log:
Enforce C language when running Python during compilation as LANGUAGE has a preference over LC_ALL.
Modified: grass/trunk/include/Make/Rules.make
--- grass/trunk/include/Make/Rules.make 2017-04-01 11:48:43 UTC (rev 70820)
+++ grass/trunk/include/Make/Rules.make 2017-04-01 12:35:46 UTC (rev 70821)
@@ -38,7 +38,7 @@
        PATH="$(ARCH_DISTDIR)/bin:$(GISBASE)/bin:$(GISBASE)/scripts:$$PATH" \
        PYTHONPATH="$(GRASS_PYTHONPATH)" \
        $(LD_LIBRARY_PATH_VAR)="$(BIN):$(GISBASE)/bin:$(GISBASE)/scripts:$(ARCH_LIBDIR):$(BASE_LIBDIR):$($(LD_LIBRARY_PATH_VAR))" \
- LC_ALL=C \
+ LC_ALL=C LANG=C LANGUAGE=C \
        $(1)
# default clean rules
grass-commit mailing list
grass-commit@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-commit
Yes, this one looks safe too, although it affects only compilation
running on non English locales thus a minority of users.
Māris.
2017-05-30 11:44 GMT+03:00 Markus Neteler <neteler@osgeo.org>:
Hi Maris,
Author: marisn
New Revision: 70821
Modified:
Log:
@@ -38,7 +38,7 @@
- LC_ALL=C \
        $(1)
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
I guess I have to revert it:
grass72_svn/lib/cdhc]$ make
if [ "" != "" -a -f "".html ] ; then make html ; fi
==============TEST=============
make test
make[1]: Entering directory '/home/mundialis/software/grass72_svn/lib/cdhc'
GISRC=/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/demolocation/.grassrc72
GISBASE=/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu
PATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/scripts:$PATH"
PYTHONPATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/etc/python:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/bin:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/scripts:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/lib:/home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/lib:"
LC_ALL=C LANG=C LANGUAGE=C OBJ.x86_64-pc-linux-gnu/test <
test_numbers.csv
TESTS:
N: 30
/bin/sh: line 1: 28663 Illegal instruction (core dumped)
test_numbers.csv
Makefile:19: recipe for target 'test' failed
make[1]: *** [test] Error 132
make[1]: Leaving directory '/home/mundialis/software/grass72_svn/lib/cdhc'
Makefile:13: recipe for target 'default' failed
make: *** [default] Error 2
Any idea why this fails?
Māris.
Hi Maris,
Author: marisn
New Revision: 70821
Modified:
Log:
@@ -38,7 +38,7 @@
- LC_ALL=C \
        $(1)
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
Hello Markus,
no idea, as it runs just fine on my system and I do not see any easy
to spot problem with test.c code. You should run it under valgrind /
gdb or just send me the core file.
Ah, yes, while at it, include also
Setting all locale stuff to C should prevent failures when translated
strings are used or comma is the decimal separator thus it *should* be
harmless.
Māris.
2017-05-31 14:56 GMT+03:00 Markus Neteler <neteler@osgeo.org>:
make test
test_numbers.csv
TESTS:
N: 30
test_numbers.csv
Māris.
Hi Maris,
Author: marisn
New Revision: 70821
Modified:
Log:
@@ -38,7 +38,7 @@
- LC_ALL=C \
        $(1)
Markus Neteler, PhD
Hi Māris,
On Wed, May 31, 2017 at 5:25 PM, Maris Nartiss <maris.gis@gmail.com> wrote:
Hello Markus,
harmless.
indeed it is.
I got into a trap with a gcc compiler flag which collided in an
"interesting" way after having virtualised my workhorse machine at the
same time when I backported the change.
Sorry for the noise, all good.
