[GRASS-dev] [GRASS-SVN] r70999 - grass-addons/grass7/raster/r.learn.ml
On Tue, May 2, 2017 at 12:45 PM, <svn_grass@osgeo.org> wrote:
Author: spawley
Date: 2017-05-02 09:45:12 -0700 (Tue, 02 May 2017)
New Revision: 70999
Modified:
   grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
   grass-addons/grass7/raster/r.learn.ml/r_learn_utils.py
Log:
r.learn.ml using multiprocessing for all cross-validations
Modified: grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
--- grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2017-05-02
13:41:15 UTC (rev 70998)
+++ grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2017-05-02
16:45:12 UTC (rev 70999)
@@ -249,13 +249,15 @@
@@ -176,9 +215,9 @@
         try:
             list(scoring_methods.keys()).index(i)
         except:
- print('Scoring ' + i + ' is not a valid scoring method')
- print('Valid methods are:')
- print(scoring_methods.keys())
+ gscript.fatal('Scoring ' + i + ' is not a valid scoring
method')
+ gscript.message('Valid methods are:')
+ gscript.message(scoring_methods.keys())
Hi Steven,
the fatal call will end the execution. What you can do is to put there a
multiline string.
Vaclav
Thanks! Made a slip-up there.
I’m working on extending multiprocessing to the permutation feature importances so I’ll make the fix tonight
Steve
Sent from my iPhone
Author: spawley
New Revision: 70999
Modified:
Log:
— grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2017-05-02 13:41:15 UTC (rev 70998)
+++ grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2017-05-02 16:45:12 UTC (rev 70999)
@@ -176,9 +215,9 @@
try:
except:
  • print(‘Scoring ’ + i + ’ is not a valid scoring method’)
  • print(‘Valid methods are:’)
  • print(scoring_methods.keys())
  • gscript.fatal(‘Scoring ’ + i + ’ is not a valid scoring method’)
  • gscript.message(‘Valid methods are:’)
  • gscript.message(scoring_methods.keys())
Hi Steven,
the fatal call will end the execution. What you can do is to put there a multiline string.
Vaclav
