TODO: make the merge-back into trunk and relbranch72 a cronjob on the
grass.osgeo.org server.
Yet I had to do several manual cleanups after the merge, so probably a
cronjob is impossible.
TODO: make the merge-back into trunk and relbranch72 a cronjob on the grass.osgeo.org server.
just out of curiosity… what kind of cleanups? Is there anything we could do when translating to avoid those cleanups afterwards?
just out of curiosity... what kind of cleanups? Is there anything we could
For example,
- disconnected (i.e. unused) translations accumulate at the end of the
.po files. This needs to be trimmed from time to time. There is a
gettext tool for that but it doesn't seem to have much effect
- if a new language is initiated on transifex, several .po file header
lines are not populated properly. To be fixed manually or some
advanced "sed" magic
- "make verify" reveils errors which need to be manually fixed.
Not sure how to address these issues in a scripted way.
On 10 September 2017 at 18:11, Markus Neteler <neteler@osgeo.org> wrote:
For example,
could we check with other projects like QGIS or ZOO?
