2018-05-16 21:49 GMT+02:00 <svn_grass@osgeo.org>:
Log:
v.select: backport trunk r73705, r72714
first of all, great job!
Just a small note, please be more informative in log messages also
about backporting. It will help going through svn log when collecting
news for release. Thanks, Martin
- return relate_geos(BIn, AGeom, bline, operator, relate, 0);
+ return relate_geos(AIn, BGeom, aline, operator, relate, 0);
}-int area_relate_geos(struct Map_info *BIn, const GEOSGeometry * AGeom,
- int barea, int operator, const char *relate)
+int area_relate_geos(struct Map_info *AIn, const GEOSGeometry *BGeom,
+ int aarea, int operator, const char *relate)
- return relate_geos(BIn, AGeom, barea, operator, relate, 1);
+ return relate_geos(AIn, BGeom, aarea, operator, relate, 1);
}-int relate_geos(struct Map_info *BIn, const GEOSGeometry * AGeom,
- int bfid, int operator, const char *relate, int area)
+int relate_geos(struct Map_info *AIn, const GEOSGeometry *BGeom,
+ int afid, int operator, const char *relate, int area)
- GEOSGeometry *BGeom = NULL;
+ GEOSGeometry *AGeom = NULL;
int found;found = 0;
if (area)
- BGeom = Vect_read_area_geos(BIn, bfid);
+ AGeom = Vect_read_area_geos(AIn, afid);
else
- BGeom = Vect_read_line_geos(BIn, bfid, NULL);
+ AGeom = Vect_read_line_geos(AIn, afid, NULL);- if (!BGeom)
+ if (!AGeom)
return 0;/*
@@ -115,8 +115,8 @@
break;
}- if (BGeom)
- GEOSGeom_destroy(BGeom);
+ if (AGeom)
+ GEOSGeom_destroy(AGeom);return found;
}Modified: grass/branches/releasebranch_7_4/vector/v.select/main.c
--- grass/branches/releasebranch_7_4/vector/v.select/main.c 2018-05-16 19:42:14 UTC (rev 72714)
+++ grass/branches/releasebranch_7_4/vector/v.select/main.c 2018-05-16 19:49:20 UTC (rev 72715)
@@ -113,9 +113,7 @@/* Alloc space for input lines array */
ALines = (int *)G_calloc(Vect_get_num_lines(&(In[0])) + 1, sizeof(int));
- AAreas = NULL;
- if (flag.reverse->answer)
- AAreas = (int *)G_calloc(Vect_get_num_areas(&(In[0])) + 1, sizeof(int));
+ AAreas = (int *)G_calloc(Vect_get_num_areas(&(In[0])) + 1, sizeof(int));/* Read field info */
IFi = Vect_get_field(&(In[0]), ifield[0]);
@@ -150,47 +148,56 @@
finishGEOS();
#endif+ if (!flag.reverse->answer) {
+ G_free(AAreas);
+ AAreas = NULL;
if (nfound != 0) {- native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
+ native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;- nfields = Vect_cidx_get_num_fields(&(In[0]));
- cats = (int **)G_malloc(nfields * sizeof(int *));
- ncats = (int *)G_malloc(nfields * sizeof(int));
- fields = (int *)G_malloc(nfields * sizeof(int));
+ nfields = Vect_cidx_get_num_fields(&(In[0]));
+ cats = (int **)G_malloc(nfields * sizeof(int *));
+ ncats = (int *)G_malloc(nfields * sizeof(int));
+ fields = (int *)G_malloc(nfields * sizeof(int));- /* Write lines */
- if (!flag.table->answer && !native) {
- /* Copy attributes for OGR output */
- Vect_copy_map_dblinks(&(In[0]), &Out, TRUE);
- write_lines(&(In[0]), IFi, ALines, AAreas,
- &Out, flag.table->answer ? 1 : 0, flag.reverse->answer ? 1 : 0,
- nfields, fields, ncats, cats);
+ /* Write lines */
+ if (!flag.table->answer && !native) {
+ /* Copy attributes for OGR output */
+ Vect_copy_map_dblinks(&(In[0]), &Out, TRUE);
+ write_lines(&(In[0]), IFi, ALines, AAreas,
+ &Out, flag.table->answer ? 1 : 0, flag.reverse->answer ? 1 : 0,
+ nfields, fields, ncats, cats);- /* Copy tables */
- if (!flag.table->answer && native) {
- copy_tabs(&(In[0]), &Out,
+ /* Copy tables */
+ if (!flag.table->answer && native) {
+ copy_tabs(&(In[0]), &Out,
+ }- /* print info about skipped features & close input maps */
- for (iopt = 0; iopt < 2; iopt++) {
- if (nskipped[iopt] > 0) {
- G_warning(_("%d features from <%s> without category skipped"),
- nskipped[iopt], Vect_get_full_name(&(In[iopt])));
- Vect_close(&(In[iopt]));
+ /* print info about skipped features & close input maps */
+ for (iopt = 0; iopt < 2; iopt++) {
+ if (nskipped[iopt] > 0) {
+ G_warning(_("%d features from <%s> without category skipped"),
+ nskipped[iopt], Vect_get_full_name(&(In[iopt])));
+ Vect_close(&(In[iopt]));
+ }- Vect_build(&Out);
- Vect_close(&Out);
+ Vect_build(&Out);
+ Vect_close(&Out);- G_done_msg(_("%d features written to output."), Vect_get_num_lines(&Out));
- } else {
- G_done_msg(_("No features found !"));
+ G_done_msg(_("%d features written to output."), Vect_get_num_lines(&Out));
+ else {
+ Vect_close(&In[0]);
+ Vect_close(&In[1]);
+ G_done_msg(_("No features found !"));
+ }exit(EXIT_SUCCESS);
}Modified: grass/branches/releasebranch_7_4/vector/v.select/overlap.c
--- grass/branches/releasebranch_7_4/vector/v.select/overlap.c 2018-05-16 19:42:14 UTC (rev 72714)
+++ grass/branches/releasebranch_7_4/vector/v.select/overlap.c 2018-05-16 19:49:20 UTC (rev 72715)
@@ -40,43 +40,17 @@/* Returns 1 if line1 from Map1 overlaps area2 from Map2,
* 0 otherwise */
-int line_overlap_area(struct line_pnts *LPoints, struct Map_info *AMap,
- int area)
+int line_overlap_area(struct line_pnts *LPoints, struct line_pnts *OPoints,
+ struct line_pnts **IPoints, int nisles)
- int i, nisles, isle;
- static struct line_pnts *APoints = NULL;
- static struct line_pnts **IPoints = NULL;
- static int isles_alloc = 0;
+ int i, isle;- G_debug(4, "line_overlap_area area = %d", area);
+ G_debug(4, "line_overlap_area area");- if (!APoints) {
- APoints = Vect_new_line_struct();
- isles_alloc = 10;
- IPoints = G_malloc(isles_alloc * sizeof(struct line_pnts *));
- for (i = 0; i < isles_alloc; i++)
- IPoints[i] = Vect_new_line_struct();
- Vect_get_area_points(AMap, area, APoints);
- nisles = Vect_get_area_num_isles(AMap, area);
- if (nisles >= isles_alloc) {
- IPoints = G_realloc(IPoints, (nisles + 10) * sizeof(struct line_pnts *));
- for (i = isles_alloc; i < nisles + 10; i++)
- isles_alloc = nisles + 10;
- for (i = 0; i < nisles; i++) {
- isle = Vect_get_area_isle(AMap, area, i);
- Vect_get_isle_points(AMap, isle, IPoints[i]);
/* Try if any of line vertices is within area */
for (i = 0; i < LPoints->n_points; i++) {- if (Vect_point_in_poly(LPoints->x[i], LPoints->y[i], APoints)) {
+ if (Vect_point_in_poly(LPoints->x[i], LPoints->y[i], OPoints)) {
int inside = 1;for (isle = 0; isle < nisles; isle++) {
@@ -99,13 +73,12 @@
/* Try intersections of line with area/isles boundary */
/* Outer boundary */- if (Vect_line_check_intersection2(LPoints, APoints, 0)) {
+ if (Vect_line_check_intersection2(LPoints, OPoints, 0)) {
G_debug(4, " -> line intersects outer area boundary");
return 1;
}for (i = 0; i < nisles; i++) {
if (Vect_line_check_intersection2(LPoints, IPoints[i], 0)) {
G_debug(4, " -> line intersects area island boundary");
return 1;Modified: grass/branches/releasebranch_7_4/vector/v.select/proto.h
--- grass/branches/releasebranch_7_4/vector/v.select/proto.h 2018-05-16 19:42:14 UTC (rev 72714)
+++ grass/branches/releasebranch_7_4/vector/v.select/proto.h 2018-05-16 19:49:20 UTC (rev 72715)
@@ -42,7 +42,8 @@/* overlap.c */
void add_aarea(struct Map_info *, int, int *, int *);
-int line_overlap_area(struct line_pnts *, struct Map_info *, int);
+int line_overlap_area(struct line_pnts *, struct line_pnts *,
+ struct line_pnts **, int);/* write.c */
void write_lines(struct Map_info *, struct field_info *, int *, int *,Modified: grass/branches/releasebranch_7_4/vector/v.select/select.c
--- grass/branches/releasebranch_7_4/vector/v.select/select.c 2018-05-16 19:42:14 UTC (rev 72714)
+++ grass/branches/releasebranch_7_4/vector/v.select/select.c 2018-05-16 19:49:20 UTC (rev 72715)
@@ -7,327 +7,404 @@
#include "proto.h"int select_lines(struct Map_info *aIn, int atype, int afield,
- struct Map_info *bIn, int btype, int bfield,
- int cat_flag, int operator, const char *relate,
- int *ALines, int *AAreas, int* nskipped)
+ struct Map_info *bIn, int btype, int bfield,
+ int cat_flag, int operator, const char *relate,
+ int *ALines, int *AAreas, int* nskipped)
- int i;
- int nalines, aline, ltype;
+ int i, ai;
+ int nblines, bline, ltype;
int nfound = 0;struct line_pnts *APoints, *BPoints;
- struct ilist *BoundList, *LList;
- struct boxlist *List, *TmpList;
+ struct line_pnts *OPoints, **IPoints;
+ int isle, nisles, isles_alloc;
+ struct ilist *BoundList;
+ struct boxlist *List;#ifdef HAVE_GEOS
initGEOS(G_message, G_fatal_error);
- GEOSGeometry *AGeom = NULL;
+ GEOSGeometry *BGeom = NULL;
#else
- void *AGeom = NULL;
+ void *BGeom = NULL;
#endifnskipped[0] = nskipped[1] = 0;
BPoints = Vect_new_line_struct();
+ OPoints = Vect_new_line_struct();
+ isles_alloc = 10;
+ IPoints = G_malloc(isles_alloc * sizeof(struct line_pnts *));
+ for (i = 0; i < isles_alloc; i++)
+ IPoints[i] = Vect_new_line_struct();
+ nisles = 0;
List = Vect_new_boxlist(1);
- TmpList = Vect_new_boxlist(1);
BoundList = Vect_new_list();
- LList = Vect_new_list();- nalines = Vect_get_num_lines(aIn);
+ nblines = Vect_get_num_lines(bIn);- /* Lines in A. Go through all lines and mark those that meets condition */
- if (atype & (GV_POINTS | GV_LINES)) {
+ /* Lines in B */
+ if (btype & (GV_POINTS | GV_LINES)) {
G_message(_("Processing features..."));- G_percent(0, nalines, 2);
- for (aline = 1; aline <= nalines; aline++) {
- struct bound_box abox;
+ G_percent(0, nblines, 2);
+ for (bline = 1; bline <= nblines; bline++) {
+ struct bound_box bbox;- G_debug(3, "aline = %d", aline);
- G_percent(aline, nalines, 2); /* must be before any continue */
+ G_debug(3, "bline = %d", bline);
+ G_percent(bline, nblines, 1); /* must be before any continue */+ /* Check type */
+ ltype = Vect_get_line_type(bIn, bline);
+ if (!(ltype & btype))
+ continue;
/* Check category */
- if (!cat_flag && Vect_get_line_cat(aIn, aline, afield) < 0) {
- nskipped[0]++;
+ if (!cat_flag && Vect_get_line_cat(bIn, bline, bfield) < 0) {
+ nskipped[1]++;
continue;
}- /* Read line and check type */
- if (operator != OP_OVERLAP) {
-#ifdef HAVE_GEOS
- AGeom = Vect_read_line_geos(aIn, aline, <ype);
-#endif
- if (!(ltype & (GV_POINT | GV_LINE)))
- continue;
+ Vect_reset_line(BPoints);- if (!AGeom)
- G_fatal_error(_("Unable to read line id %d from vector map <%s>"),
- aline, Vect_get_full_name(aIn));
- else {
- ltype = Vect_read_line(aIn, APoints, NULL, aline);
- if (!(ltype & atype))
- continue;
- Vect_get_line_box(aIn, aline, &abox);
+ Vect_get_line_box(bIn, bline, &bbox);- /* Check if this line overlaps any feature in B */
- /* x Lines in B */
- if (btype & (GV_POINTS | GV_LINES)) {
- int found = 0;
+ /* Check if this line overlaps any feature in A */
+ /* x Lines in A */
+ if (atype & (GV_POINTS | GV_LINES)) {/* Lines */
- Vect_select_lines_by_box(bIn, &abox, btype, List);
- for (i = 0; i < List->n_values; i++) {
- int bline;
+ Vect_select_lines_by_box(aIn, &bbox, atype, List);
+ for (ai = 0; ai < List->n_values; ai++) {
+ int aline;- bline = List->id[i];
- G_debug(3, " bline = %d", bline);
+ aline = List->id[ai];
+ G_debug(3, " aline = %d", aline);
+ if (ALines[aline] == 1)
+ continue;
+ /* Check type */
+ ltype = Vect_get_line_type(aIn, aline);
+ if (!(ltype & atype))
+ continue;
if (!cat_flag &&
- Vect_get_line_cat(bIn, bline, bfield) < 0) {
- nskipped[1]++;
+ Vect_get_line_cat(aIn, aline, afield) < 0) {
+ nskipped[0]++;
continue;
}if (operator != OP_OVERLAP) {
#ifdef HAVE_GEOS
- if(line_relate_geos(bIn, AGeom,
- bline, operator, relate)) {
+ if (!BGeom)
+ BGeom = Vect_read_line_geos(bIn, bline, <ype);
+ if (!BGeom)
+ G_fatal_error(_("Unable to read line id %d from vector map <%s>"),
+ bline, Vect_get_full_name(bIn));- found = 1;
- break;
+ if (line_relate_geos(aIn, BGeom, aline,
+ operator, relate)) {
+ ALines[aline] = 1;
+ nfound += 1;
#endif
else {
- Vect_read_line(bIn, BPoints, NULL, bline);
+ if (BPoints->n_points == 0)
+ Vect_read_line(bIn, BPoints, NULL, bline);
+ Vect_read_line(aIn, APoints, NULL, aline);- if (Vect_line_check_intersection2(APoints, BPoints, 0)) {
- found = 1;
- break;
+ if (Vect_line_check_intersection2(BPoints, APoints, 0)) {
+ nfound += 1;
- if (found) {
- ALines[aline] = 1;
- nfound += 1;
- continue; /* Go to next A line */
}- /* x Areas in B. */
- if (btype & GV_AREA) {
+ /* x Areas in A. */
+ if (atype & GV_AREA) {- Vect_select_areas_by_box(bIn, &abox, List);
- int barea;
+ Vect_select_areas_by_box(aIn, &bbox, List);
+ int aarea;- barea = List->id[i];
- G_debug(3, " barea = %d", barea);
+ aarea = List->id[ai];
+ G_debug(3, " aarea = %d", aarea);- if (Vect_get_area_cat(bIn, barea, bfield) < 0) {
- nskipped[1]++;
+ if (AAreas[aarea] == 1)
continue;
+ if (Vect_get_area_centroid(aIn, aarea) < 1)
+ continue;
+ if (!cat_flag &&
+ Vect_get_area_cat(aIn, aarea, afield) < 0) {
+ nskipped[0]++;
+ continue;
#ifdef HAVE_GEOS
- if(area_relate_geos(bIn, AGeom,
- barea, operator, relate)) {
+ if (!BGeom)
+ if (!BGeom)
+ if (area_relate_geos(aIn, BGeom, aarea,
+ add_aarea(aIn, aarea, ALines, AAreas);
nfound += 1;
- break;
#endif
else {
- if (line_overlap_area(APoints, bIn, barea)) {
+ Vect_get_area_points(aIn, aarea, OPoints);
+ nisles = Vect_get_area_num_isles(aIn, aarea);
+ if (nisles >= isles_alloc) {
+ IPoints = G_realloc(IPoints, (nisles + 10) * sizeof(struct line_pnts *));
+ for (i = isles_alloc; i < nisles + 10; i++)
+ isles_alloc = nisles + 10;
+ for (i = 0; i < nisles; i++) {
+ isle = Vect_get_area_isle(aIn, aarea, i);
+ Vect_get_isle_points(aIn, isle, IPoints[i]);
+ if (line_overlap_area(BPoints, OPoints, IPoints, nisles)) {
nfound += 1;
- break;
#ifdef HAVE_GEOS
- GEOSGeom_destroy(AGeom);
+ if (BGeom != NULL) {
+ GEOSGeom_destroy(BGeom);
+ BGeom = NULL;
#endif
- AGeom = NULL;
}- /* Areas in A. */
- if (atype & GV_AREA) {
- int aarea, naareas;
+ /* Areas in B. */
+ if (btype & GV_AREA) {
+ int barea, nbareas, bcentroid;G_message(_("Processing areas..."));
- naareas = Vect_get_num_areas(aIn);
+ nbareas = Vect_get_num_areas(bIn);- G_percent(0, naareas, 2);
- for (aarea = 1; aarea <= naareas; aarea++) {
+ G_percent(0, nbareas, 1);
+ for (barea = 1; barea <= nbareas; barea++) {
+ struct bound_box bbox;- G_percent(aarea, naareas, 1);
+ G_percent(barea, nbareas, 2);- if (Vect_get_area_cat(aIn, aarea, afield) < 0) {
- nskipped[0]++;
+ if ((bcentroid = Vect_get_area_centroid(bIn, barea)) < 1)
continue;
- Vect_get_area_box(aIn, aarea, &abox);
- abox.T = PORT_DOUBLE_MAX;
- abox.B = -PORT_DOUBLE_MAX;- if (operator != OP_OVERLAP) {
-#ifdef HAVE_GEOS
- AGeom = Vect_read_area_geos(aIn, aarea);
-#endif
- if (!AGeom)
- G_fatal_error(_("Unable to read area id %d from vector map <%s>"),
- aarea, Vect_get_full_name(aIn));
+ if (!cat_flag &&
+ Vect_get_area_cat(bIn, barea, bfield) < 0) {
+ nskipped[1]++;
+ continue;
}- /* x Lines in B */
+ Vect_reset_line(BPoints);- for (i = 0; i < List->n_values; i++) {
- int bline;
+ Vect_get_area_box(bIn, barea, &bbox);
+ bbox.T = PORT_DOUBLE_MAX;
+ bbox.B = -PORT_DOUBLE_MAX;- bline = List->id[i];
+ Vect_select_lines_by_box(aIn, &bbox, atype, List);+ for (ai = 0; ai < List->n_values; ai++) {
+ int aline;
+ continue;
+ /* Check type */
+ continue;
if (!cat_flag &&
- nskipped[1]++;
+ nskipped[0]++;
continue;
#ifdef HAVE_GEOS
- add_aarea(aIn, aarea, ALines, AAreas);
+ if (!BGeom)
+ BGeom = Vect_read_area_geos(bIn, barea);
+ if (!BGeom)
+ G_fatal_error(_("Unable to read area id %d from vector map <%s>"),
+ barea, Vect_get_full_name(bIn));
nfound += 1;
- break;
#endif
else {
+ if (BPoints->n_points == 0) {
+ Vect_read_line(bIn, BPoints, NULL, bcentroid);
+ Vect_get_area_points(bIn, barea, OPoints);
+ nisles = Vect_get_area_num_isles(bIn, barea);
+ isle = Vect_get_area_isle(bIn, barea, i);
+ Vect_get_isle_points(bIn, isle, IPoints[i]);
+ }- if (line_overlap_area(BPoints, aIn, aarea)) {
+ if (line_overlap_area(APoints, OPoints, IPoints, nisles)) {
nfound += 1;
- continue;
}- /* x Areas in B */
- int naisles;
- int found = 0;
+ /* x Areas in A */
+ if (atype & GV_AREA) {- /* List of areas B */
+ /* List of areas A */
+ Vect_select_areas_by_box(aIn, &bbox, List);- /* Make a list of features forming area A */
- Vect_reset_list(LList);
+ int found = 0;
+ int aarea, acentroid;- Vect_get_area_boundaries(aIn, aarea, BoundList);
- for (i = 0; i < BoundList->n_values; i++) {
- Vect_list_append(LList, abs(BoundList->value[i]));
+ continue;- naisles = Vect_get_area_num_isles(aIn, aarea);
+ if ((acentroid = Vect_get_area_centroid(aIn, aarea)) < 1)
+ continue;- for (i = 0; i < naisles; i++) {
- int j, aisle;
+ if (!cat_flag &&
+ nskipped[0]++;
+ continue;
+ }- aisle = Vect_get_area_isle(aIn, aarea, i);
- Vect_get_isle_boundaries(aIn, aisle, BoundList);
- for (j = 0; j < BoundList->n_values; j++) {
- Vect_list_append(LList, BoundList->value[j]);
+ if (operator != OP_OVERLAP) {
+#ifdef HAVE_GEOS
+ if (!BGeom)
+ if (!BGeom)
+ found = 1;
+#endif
+ else {
+ }- Vect_select_areas_by_box(bIn, &abox, TmpList);
+ /* A inside B ? */
+ Vect_read_line(aIn, APoints, NULL, acentroid);
+ found = 1;
+ }- for (i = 0; i < LList->n_values; i++) {
- int j;
+ /* B inside A ? */
+ if (!found) {
+ struct bound_box abox;- aline = abs(LList->value[i]);
- Vect_read_line(aIn, APoints, NULL, aline);
+ Vect_get_area_box(aIn, aarea, &abox);
+ abox.T = PORT_DOUBLE_MAX;
+ abox.B = -PORT_DOUBLE_MAX;- for (j = 0; j < TmpList->n_values; j++) {
- int barea, bcentroid;
+ if (Vect_point_in_area(BPoints->x[0], BPoints->y[0], aIn,
+ aarea, &abox)) {
+ found = 1;
+ }- barea = TmpList->id[j];
- nskipped[1]++;
- continue;
+ /* A overlaps B ? */
+ if (!found) {
+ Vect_get_area_boundaries(aIn, aarea, BoundList);
+ for (i = 0; i < BoundList->n_values; i++) {
+ Vect_read_line(aIn, APoints, NULL, abs(BoundList->value[i]));
+ found = 1;
+ break;
}- /* Check if any centroid of area B is in area A.
- * This test is important in if area B is completely within area A */
- if ((bcentroid = Vect_get_area_centroid(bIn, barea)) > 0)
- Vect_read_line(bIn, BPoints, NULL, bcentroid);
- else {
- double x, y;
+ if (!found) {
+ int j, naisles;- Vect_get_point_in_area(bIn, barea, &x, &y);
- Vect_reset_line(BPoints);
- Vect_append_point(BPoints, x, y, 0.0);
+ naisles = Vect_get_area_num_isles(aIn, aarea);
+ for (j = 0; j < naisles; j++) {- if (operator != OP_OVERLAP) {
-#ifdef HAVE_GEOS
- found = 1;
- break;
+ isle = Vect_get_area_isle(aIn, aarea, j);
+ Vect_get_isle_boundaries(aIn, isle, BoundList);
+ found = 1;
+ break;
+ if (found)
+ break;
-#endif
- else {
- if (Vect_point_in_area(BPoints->x[0], BPoints->y[0], aIn,
- aarea, &abox)) {
- found = 1;
- break;
- /* Check intersectin of lines from List with area B */
- found = 1;
- break;
if (found) {
- nfound += 1;
- break;
+ nfound += 1;
#ifdef HAVE_GEOS
+ BGeom = NULL;
#endif
- AGeom = NULL;
}@@ -334,9 +411,7 @@
Vect_destroy_line_struct(APoints);
Vect_destroy_line_struct(BPoints);
Vect_destroy_list(BoundList);
- Vect_destroy_list(LList);
Vect_destroy_boxlist(List);
- Vect_destroy_boxlist(TmpList);return nfound;
}Modified: grass/branches/releasebranch_7_4/vector/v.select/write.c
--- grass/branches/releasebranch_7_4/vector/v.select/write.c 2018-05-16 19:42:14 UTC (rev 72714)
+++ grass/branches/releasebranch_7_4/vector/v.select/write.c 2018-05-16 19:49:20 UTC (rev 72715)
@@ -6,7 +6,7 @@
struct Map_info *Out, int table_flag, int reverse_flag,
int nfields, int *fields, int *ncats, int **cats)
- int i, f, j, aline, nalines;
+ int i, f, j, aline, nalines;
int atype;struct line_pnts *APoints;
@@ -59,6 +59,7 @@if (!table_flag && (IFi != NULL)) {
for (i = 0; i < ACats->n_cats; i++) {
+ f = -1;
for (j = 0; j < nfields; j++) { /* find field */
if (fields[j] == ACats->field[i]) {
f = j;
@@ -65,8 +66,10 @@
break;
- cats[f][ncats[f]] = ACats->cat[i];
- ncats[f]++;
+ if (f >= 0) {
+ cats[f][ncats[f]] = ACats->cat[i];
+ ncats[f]++;
}_______________________________________________
grass-commit mailing list
grass-commit@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
