[GRASS-dev] [GRASS-SVN] r73360 - grass/branches/releasebranch_7_6/scripts/r.import
Markus,
Could you explain this ? Does this mean that the memory parameter in r.in.gdal is now automagic ? Or why doesn't it make sens to let the user define in r.import the memory size ?
Moritz
On 17/09/18 15:30, svn_grass@osgeo.org wrote:
Author: neteler
Date: 2018-09-17 06:30:25 -0700 (Mon, 17 Sep 2018)
New Revision: 73360
Modified:
    grass/branches/releasebranch_7_6/scripts/r.import/r.import.py
Log:
r.import: remove hardcoded memory limit (r.in.gdal will take care)
Modified: grass/branches/releasebranch_7_6/scripts/r.import/r.import.py
--- grass/branches/releasebranch_7_6/scripts/r.import/r.import.py 2018-09-17 13:29:35 UTC (rev 73359)
+++ grass/branches/releasebranch_7_6/scripts/r.import/r.import.py 2018-09-17 13:30:25 UTC (rev 73360)
@@ -39,7 +39,6 @@
  #% type: integer
  #% required: no
  #% multiple: no
-#% options: 0-2047
  #% label: Maximum memory to be used (in MB)
  #% description: Cache size for raster rows
  #% answer: 300
grass-commit mailing list
grass-commit@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-commit
On Mon, Sep 17, 2018 at 3:39 PM Moritz Lennert <mlennert@club.worldonline.be> wrote:
Markus,
r.in.gdal is now automagic ? Or why doesn’t it make sens to let the user
Markus N and me were discussing this together: r73360 removes the 2047 MB limit in r.import, nothing else. It is now possible in r.import to define memory larger than 2047 MB. r.in.gdal has this limit only for GDAL 1.8 and earlier and does the checks (r.in.gdal will take care of the memory answer).
Markus M
Moritz
Author: neteler
New Revision: 73360
Modified:
Log:
— grass/branches/releasebranch_7_6/scripts/r.import/r.import.py 2018-09-17 13:29:35 UTC (rev 73359)
@@ -39,7 +39,6 @@
#% type: integer
#% required: no
#% multiple: no
-#% options: 0-2047
#% answer: 300
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
