On Fri, Jan 18, 2019 at 12:33 AM <svn_grass@osgeo.org> wrote:
Author: neteler
Date: 2019-01-17 21:33:12 -0800 (Thu, 17 Jan 2019)
New Revision: 73973Added:
grass/trunk/testsuite/examples/
grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
Removed:
grass/trunk/testsuite/test_framework_GRASS_GIS_with_NC.sh
Log:
test_framework_GRASS_GIS_with_NC.sh: moved into ‘examples/’ subdir to prevent from undesired execution in online testsuite
Just to be clear here, the tests running at fatra.cnr.ncsu.edu use basically what is in the documentation [1], i.e. what is in test_framework_GRASS_GIS_with_NC.sh. If test_framework_GRASS_GIS_with_NC.sh would be directly in testsuite dir, it will attempt to execute itself on any computer (through the code and rules in the gunittest package).
