On Tue, Jan 22, 2019 at 3:51 AM <svn_grass@osgeo.org> wrote:
Author: hcho
Date: 2019-01-21 18:51:33 -0800 (Mon, 21 Jan 2019)
New Revision: 73995
Modified:
grass/trunk/scripts/v.db.addtable/v.db.addtable.py
Log:
v.db.addtable: Do not create unique index from this script; v.db.connect will try to create it again causing some drivers to fail (PostgreSQL)
If there is a linked table, v.db.addtable stops in line 106. If not, this script doesn’t create a unique index and calls v.db.connect. v.db.connect adds a db link in line 317 and creates a unique index (db_create_index2) in line 334 if linking was successful. SQLite didn’t complain when both modules created the same unique index, but PostgreSQL failed in v.db.connect (2nd time creating the same unique index). Not sure which code was added first/later. I think it’s more of how we design both modules. v.db.connect will fail if we try to link a table with a unique index. Isn’t v.db.connect supposed to “just” connect a table to a layer (without creating any database objects like index)? Which module should be responsible for creating unique indices?
Before this commit:
v.db.addtable creates unique index
v.db.connect tries to create unique index again ==> fatal error
After this commit:
v.db.addtable doesn’t create unique index
v.db.connect creates unique index
Probably, it should be:
v.db.addtable should create unique index
v.db.connect shouldn’t try to create unique index? Just “connect”…
Huidae
Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
Open Source GIS Developer, GRASS GIS Development Team
On Sat, Jan 26, 2019 at 2:50 PM Huidae Cho <grass4u@gmail.com> wrote:
Markus,
Before this commit:
After this commit:
Yes, this is the preferred solution. Consider v.db.connect -d followed by v.db.connect, i.e. disconnecting a table and then reconnecting the same table: in this case v.db.connect should also fail with PostgreSQL. IMHO, a unique index should only be created when the table is created.
Markus M
Huidae
On Sat, Jan 26, 2019 at 7:39 AM Markus Neteler <neteler@osgeo.org> wrote:
Author: hcho
New Revision: 73995
Modified:
Log:
Markus,
What do you mean with “failed”? v.db.connect will issue a warning if it can not create an index but finish successfully.
Markus M
Before this commit:
After this commit:
Markus M
Huidae
Author: hcho
New Revision: 73995
Modified:
Log:
You’re right. It was a warning with PostgresSQL error messages (attached below), not a fatal error. But I don’t think there should be any warning (or PostgreSQL errors) because the user didn’t do anything wrong here (v.edit map tool=create; v.db.addtable).
DBMI-PostgreSQL driver error:
Unable to create index: create unique index tmp2_cat on tmp2 ( cat )
ERROR: relation “tmp2_cat” already exists
WARNING: Cannot create index
here
WARNING: Values in column will be overwritten
Reading features…
100%
Updating database…
100%
Markus,
Markus M
Before this commit:
After this commit:
Markus M
Huidae
Author: hcho
New Revision: 73995
Modified:
Log:
Hmm yes I agree. At least for v.db.addtable the index can be created by v.db.connect when the new table is actually linked to the vector map.
You might still get these PG errors when you try to connect an already existing table, but this is probably not happening very often, and v.db.connect finishes anyway.
Markus M
here
Reading features…
100%
Updating database…
100%
Markus,
Markus M
Before this commit:
After this commit:
Markus M
Huidae
Author: hcho
New Revision: 73995
Modified:
Log:
Yes. Like you said, v.db.connect followed by v.db.connect -d gives me the same pg errors and grass warning. I agree with you that the preferred solution would be to create the index in v.db.addtable, not in v.db.connect “if” no modules rely on v.db.connect for creating the unique index.
Huidae
I just did a quick search and found that these modules (i.segment.stats, r.mwprecip, v.in.geopaparazzi, v.link.precip, v.out.gps, v.ply.rectify, v.unpack) create/copy new tables themselves without the index and invoke v.db.connect. For now, we cannot move index creation to v.db.addtable.
Huidae
Just for our records, actually, PostgreSQL 9.5+ supports CREATE INDEX IF NOT EXISTS, which the grass sqlite driver already does (this is why we didn’t have this warning with sqlite before). Not sure if we want to enforce the minimum version for a specific database though.
Best,
Huidae
Yes, removing index creation from v.db.connect would require that all modules relying on v,db.connect must create an index themselves, this is not very elegant. So let’s leave it as it is now.
Markus M
Huidae
Markus M
here
Reading features…
100%
Updating database…
100%
Markus,
Markus M
Before this commit:
After this commit:
Markus M
Huidae
Author: hcho
New Revision: 73995
Modified:
Log:
We can use “if not exists” for PostgreSQL 9.5+, otherwise not, please try trunk r74042.
Markus M
Best,
Huidae
Huidae
Markus M
here
Reading features…
100%
Updating database…
100%
Markus,
Markus M
Before this commit:
After this commit:
Markus M
Huidae
Author: hcho
New Revision: 73995
Modified:
Log:
trunk r74043
Markus M
Best,
Huidae
Huidae
Markus M
here
Reading features…
100%
Updating database…
100%
Markus,
Markus M
Before this commit:
After this commit:
Markus M
Huidae
Author: hcho
New Revision: 73995
Modified:
Log:
