Hi Stefan,
<svn_grass@osgeo.org> schrieb am Mi., 24. Apr. 2019, 22:41:
Author: sbl
Date: 2019-04-24 13:41:37 -0700 (Wed, 24 Apr 2019)
New Revision: 74423
Modified:
grass/trunk/raster/r.basins.fill/testsuite/testrbf.py
Log:
deactivate erroneous test; see #3822
Modified: grass/trunk/raster/r.basins.fill/testsuite/testrbf.py
— grass/trunk/raster/r.basins.fill/testsuite/testrbf.py 2019-04-24 20:33:36 UTC (rev 74422)
+++ grass/trunk/raster/r.basins.fill/testsuite/testrbf.py 2019-04-24 20:41:37 UTC (rev 74423)
@@ -8,8 +8,10 @@
License (>=v2). Read the file COPYING that comes with GRASS
for details.
+import unittest
from grass.gunittest.case import TestCase
+@unittest.skip(“See #3822”)
class TestRasterbasin(TestCase):
celevation=‘elevation’
tgeology=‘geology’
Did you see the attachment?
I’d prefer to fix the test rather than skip it (and forget)…
Hi Markus,
Unfortunately, the test will have to be more or less rewritten, which is why I for now chose to deactivate it with an info message pointing to the related ticket.
Alternatively, it could be shortened to the one assertModule test that it actually performs on r.basin.fill (see also comments in the ticket).
Also skipped tests should remain visible in test reports e.g. on fatra BTW.
Stefan
Hi Stefan,
Author: sbl
New Revision: 74423
Modified:
Log:
@@ -8,8 +8,10 @@
for details.
+import unittest
[+@unittest.skip(“See](mailto:+@unittest.skip(%22See) #3822”)
tgeology=‘geology’
