[GRASS-dev] GRASS trac system, join user login
it seems that I accidentally created two users
a “jradinger” and a “JRadinger” in trac system?.
Is it possible for an admin to join both users (end the posts)
and to delete one?
This would mean that you have two OSGeo-IDs.
http://www.osgeo.org/osgeo_userid
But I see only one entry:
https://www2.osgeo.org/cgi-bin/ldap_web_search.py?query=JRadinger
Why do you mean to have two?
After login as “jradinger” and check all tickets reported by me ({9} All Tickets Reported by Me – GRASS GIS))
I see only three tickets and I am missing eg. following ticket (http://trac.osgeo.org/grass/ticket/1679) which
was created by “JRadinger” and isn’t displayed in MY tickets…Ok this ticket is already closed but it is still one
of my tickets?!
I am just confused, but maybe I am doing something wrong…
/johannes
On Thu, Jul 5, 2012 at 7:26 AM, Johannes Radinger <jradinger@gmx.at> wrote:
After login as "jradinger" and check all tickets reported by me ({9} All
was created by "JRadinger" and isn't displayed in MY tickets....Ok this
of my tickets?!
No idea but: I have changed there the reporter
from JRadinger to jradinger. This should solve it.
> of my tickets?!
Thank you! Now all tickets are assign to jradinger. I tried to trace the
problem and found out that the login is not case sensitive (I can log in with both names) but the tickets are assigned only to the name used for login. That is strange as there is only one user ID. I am using Safari (on MacOSX) as a browser for http://trac.osgeo.org/grass/wiki.
/Johannes
2012/7/5 Johannes Radinger <JRadinger@gmx.at>:
probably should be reported as ticket [1] (Component: System Admin)?
Martin
[1] https://trac.osgeo.org/osgeo
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
