[GRASS-dev] [GRASS-user] Cannot launch g.copy from GRASS shell
On Sun, Apr 10, 2016 at 3:03 PM, Blumentrath, Stefan
<Stefan.Blumentrath@nina.no> wrote:
Try g.copy --ui
It is obviously confusing that the --ui flag is needed for some modules to start the GUI...
I see. It's because there is no required parameter. It should be
solved using G_option_required(), but the options are in an array, so
I don't know how to use it in this case.
Anna
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of roy roy
Sent: 10. april 2016 20:52
To: GRASS user list <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] Cannot launch g.copy from GRASS shell
OK thanks Anna,
what i'm going to describe happens in windows 64 bit osgeo4w GRASS and on ubuntu 64bit GRASS from "ubuntugis-unstable" ppa
- open up GRASS GIS
- on the shell / console (not in the GRASS GUI) write g.copy and hit ENTER
- nothing happens
if you do the same with another module (e.g. g.remove) the module gui regularly opens up
Il 10/04/2016 20:22, Anna Petrášová ha scritto:
On Sun, Apr 10, 2016 at 10:31 AM, roy roy <royroge@outlook.com> wrote:
While i can launch g.copy from the GRASS gui i cannot launch the
exact same module from the shell, is there some sort of bug?
It should work, please be more specific - any error? which platform?
GRASS version?
Best,
Anna
thanks, roy.
grass-user mailing list
