On Tue, Jul 21, 2015 at 11:03 AM, henk witte <henk.witte@groenholland.nl>
wrote:
Hello All,
If I create a thematic map (d.vect.thematic) I can re open and edit it in
the GUI fine during a session. However, if I re-open the workspace and try
to reopen the properties of the thematic map I get an error (I can render
the map without problems). This means I have to recreate all thematic maps
if I need to make some change.The traceback shows:
File "C:\Program Files (x86)\GRASS GIS
7.0.0\gui\wxpython\lmgr\layertree.py", line 1276, in
OnActivateLayer
self.PropertiesDialog(layer)
7.0.0\gui\wxpython\lmgr\layertree.py", line 1244, in
PropertiesDialog
completed = (self.GetOptData,layer,params))
7.0.0\gui\wxpython\gui_core\forms.py", line 2413, in
ParseCommand
get_dcmd = get_dcmd, layer = layer)
7.0.0\gui\wxpython\gui_core\forms.py", line 466, in __init__
frame = self)
7.0.0\gui\wxpython\gui_core\forms.py", line 1463, in
__init__
default_color, label_color = utils.color_resolve(p['value'])
7.0.0\gui\wxpython\core\utils.py", line 989, in
color_resolve
rgb = tuple(map(int, color.split(':')))
ValueError
invalid literal for int() with base 10: '20,254'
I hopefully fixed the problem in r65750, so it will be available in the
next release. You can test daily builds here:
http://wingrass.fsv.cvut.cz/grass70/
Anna
Henk Witte
Groenholland Geo-energysystems
Valschermkade 26
1059CD Amsterdam
T: +31 (0)20 6159050
M: +31 (0)628176535
E: henk.witte@groenholland.nl
grass-user mailing list
grass-user@lists.osgeo.org
