[GRASS-dev] [GRASS-user] Create_iwave.py script error for template creation -i.atcorr module-reg
On Wed, Oct 24, 2018 at 8:28 AM kameswari devi <kams.devi@gmail.com> wrote:
Please check the file i have used and error received as an
attachment.I tried to interpolate using Create_iwave.py script for
i.atcorr module but errors are observed. please suggest me thank you
Using create_iwave.py in GRASS 7.7,
python create_iwave.py sensors_csv/testint_B131to142.csv
works fine without errors. Which GRASS version are you using?
Markus M
Regards
kameswari devi P
grass-user mailing list
grass-user@lists.osgeo.org
I looks like you have a mixed python installation, with some libraries coming from ArcGIS and others from your grass installation. Not sure that’s a problem but, if it works on Markus M computer, it’s worth checking it out.
On Wed, Oct 24, 2018 at 5:08 PM Markus Metz <markus.metz.giswork@gmail.com> wrote:
Markus M
Regards
kameswari devi P
Grass6.4.4 Used for this.
On Thu 25 Oct, 2018, 01:38 Markus Metz, <markus.metz.giswork@gmail.com> wrote:
Markus M
Regards
kameswari devi P
If you want to use i.atcorr, you should use GRASS 7.4 or higher because quite a few bugs have been fixed in the meantime.
Markus M
Markus M
Regards
kameswari devi P
