[Removing grass-user as this is more grass-dev or bug tracking thing.]
On Thu, Sep 20, 2018 at 12:27 PM Frank David <frank.david@geophom.fr> wrote:
Hello,
Grass 7.4 (and 7.5) failed to open a workspace (with many layers and
folders). The waiting box stay open and the workspace is not fully loaded.
If I try to save the current workspace, I got the following message :"Échec d’écriture des paramètres de l’espace de travail courant.
Hi, back translating using a po file, it says
“Writing current settings to workspace file failed.”
So it looks like saving, not loading workspace. Based on the None for cmd below and something I noticed in the past, I would say it is saving with a layer dialog open, but OK or Apply was not pressed. Can you please test it if that’s it and open a ticket with steps to reproduce it?
Best,
Vaclav
Raison: ‘NoneType’ object has no attribute ‘GetCmd’
File “/usr/local/grass-7.5.svn/gui/wxpython/lmgr/frame.py”, line
1656, in SaveToWorkspaceFile
WriteWorkspaceFile(lmgr=self, file=tmpfile)
File “/usr/local/grass-7.5.svn/gui/wxpython/core/workspace.py”, line
900, in init
self.__writeLayer(mapTree, item)
959, in __writeLayer
item, key=‘maplayer’).GetCmd(
AttributeError: ‘NoneType’ object has no attribute ‘GetCmd’"I run Grass on Debian9
Regards
grass-user mailing list
grass-user@lists.osgeo.org
