[GRASS-dev] [GRASS-user] g.gui.animation fails at launching
On Thu, Oct 30, 2014 at 5:26 AM, Annalisa Minelli <annagrass6@gmail.com>
wrote:
I'm experiencing a problem in launching g.gui.animation..
wich doesn't load and it returns me the following error:
"Error in atexit._run_exitfuncs"
..here the complete output: http://pastebin.com/FwMQa1jF
Hm, not sure when this got broken. For now, you can edit file
gui/wxpython/animation/g.gui.animation.py and instead of last line
GuiModuleMain(main)
use
main()
and recompile. That should fix it, but it will block your command line
unless you use &
Anna
I compiled GRASS yesterday (checking out the grass70 release version), it
seemed fine and I used this configure:
./configure --with-proj-share=/usr/local/share/proj/ --with-python
--with-cxx --with-freetype --with-freetype-includes=/usr/include/freetype2/
--with-includes=/usr/local/lib --with-wxwidgets --enable-largefile
--enable-64bit --with-sqlite --with-sqlite-includes=/usr/include/
--with-opengl --with-postgres
--with-postgres-includes=/usr/include/postgresql/
--with-tcltk-includes=/usr/include/tcl8.5 --with-gdal --with-netcdf
--with-ffmpeg --with-motif --with-geos --with-odbc --with-mysql
--with-mysql-includes=/usr/include/mysql/
Many thanks,
Annalisa
grass-user mailing list
grass-user@lists.osgeo.org
On Thu, Oct 30, 2014 at 8:38 AM, Anna Petrášová <kratochanna@gmail.com>
wrote:
the error is caused by r62374
http://trac.osgeo.org/grass/changeset/62374/grass/trunk
I don't say this commit is wrong, maybe the GuiModuleMain is wrong. Any
opinion? I remember GuiModuleMain had some problems on Mac, too.
Anna
GuiModuleMain(main)
use
main()
unless you use &
Anna
Many thanks,
Annalisa
On Thu, Oct 30, 2014 at 10:48 AM, Anna Petrášová <kratochanna@gmail.com>
wrote:
If there won't be any progress on this soon, I will probably stop using the
process forking in GuiModuleMain for g.gui.* modules. It seems that it
brings a lot of problems and typing & after the command does the same
without any problems. On Windows, we can't use it anyway and I remember
some crashing on Mac, too. So let's have it less convenient but more stable.
Anna
Anna
GuiModuleMain(main)
use
main()
unless you use &
Anna
it seemed fine and I used this configure:
Many thanks,
Annalisa
On Fri, Oct 31, 2014 at 5:25 PM, Anna Petrášová <kratochanna@gmail.com>
wrote:
the process forking in GuiModuleMain for g.gui.* modules. It seems that it
OK, I removed the the current GuiModuleMain implementation, so
g.gui.animation should work again. We have to find less fragile solution or
just get used to typing &.
Anna
Anna
GuiModuleMain(main)
use
main()
unless you use &
Anna
Many thanks,
Annalisa
Thank you so much Anna,
it works :slight_smile:
Annalisa
2014-10-30 13:38 GMT+01:00 Anna Petrášová <kratochanna@gmail.com>:
On Thu, Oct 30, 2014 at 5:26 AM, Annalisa Minelli <annagrass6@gmail.com> wrote:
I’m experiencing a problem in launching g.gui.animation…
wich doesn’t load and it returns me the following error:
“Error in atexit._run_exitfuncs”
…here the complete output: http://pastebin.com/FwMQa1jF
Hm, not sure when this got broken. For now, you can edit file gui/wxpython/animation/g.gui.animation.py and instead of last line
GuiModuleMain(main)
use
main()
and recompile. That should fix it, but it will block your command line unless you use &
Anna
I compiled GRASS yesterday (checking out the grass70 release version), it seemed fine and I used this configure:
./configure --with-proj-share=/usr/local/share/proj/ --with-python --with-cxx --with-freetype --with-freetype-includes=/usr/include/freetype2/ --with-includes=/usr/local/lib --with-wxwidgets --enable-largefile --enable-64bit --with-sqlite --with-sqlite-includes=/usr/include/ --with-opengl --with-postgres --with-postgres-includes=/usr/include/postgresql/ --with-tcltk-includes=/usr/include/tcl8.5 --with-gdal --with-netcdf --with-ffmpeg --with-motif --with-geos --with-odbc --with-mysql --with-mysql-includes=/usr/include/mysql/
Many thanks,
Annalisa
