[Changing list to grass-dev, at least the traceback is compilation problem.]
On Mon, Oct 14, 2013 at 4:34 AM, Johannes Radinger <johannesradinger@gmail.com> wrote:
I want to install G7 and G6.4.3 as well as several add-ons on a freshly installed Xubuntu (12.04) machine (Virtualbox) for testing purposes. Therefore I run following commands after Xubuntu installation and update of the system:
sudo add-apt-repository ppa:grass/grass-devel
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
sudo apt-get install grass643 grass70 grass-gui grass70-guiHowever after successful installation I run into following two problems:
- When I try to launch G7-gui (e.g. with standard NC example dataset) I get following error:
Launching GUI in the background, please wait…
GRASS 7.0.svn (nc_basic_spm_grass7):~ > Traceback (most recent call last):
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 143, in
sys.exit(main())
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 136, in main
app = GMApp(workspaceFile)
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 50, in init
wx.App.init(self, False)
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7981, in init
self._BootstrapApp()
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py”, line 7555, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/usr/lib/grass70/etc/gui/wxpython/wxgui.py”, line 84, in OnInit
workspace = self.workspaceFile)
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py”, line 108, in init
self._menuTreeBuilder = LayerManagerMenuData()
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py”, line 40, in init
MenuTreeModelBuilder.init(self, filename, expandAddons=expandAddons)
File “/usr/lib/grass70/etc/gui/wxpython/core/menutree.py”, line 69, in init
xmlTree = etree.parse(filename)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1183, in parse
tree.parse(source, parser)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 657, in parse
self._root = parser.close()
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1655, in close
self._raiseerror(v)
File “/usr/lib/python2.7/xml/etree/ElementTree.py”, line 1507, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
About the traceback, it seems as a compilation issue in the PPA. During compilation the menudata.xml file should created in gui/wxpython/xml/ but probably it is not.
There is a note about some changes in the repository at:
https://launchpad.net/~grass
Can someone from the Launchpad GRASS GIS team check/explain what is happening? With this file we have problems at Mac but Ubuntu and Windows were successfully tested (but still, the related Makefile is bit strange, so that might be a problem).
Here is what my ls says after I run make:
$ ls gui/wxpython/xml/
grass-gxm.dtd menudata.dtd menudata.xml toolboxes.dtd
grass-gxw.dtd menudata_modeler.xml module_items.dtd toolboxes.xml
main_menu.dtd menudata_psmap.xml module_tree_menudata.xml wxgui_items.dtd
main_menu.xml menudata.README module_tree.xml wxgui_items.xml
$ ls dist.i686-pc-linux-gnu/etc/gui/wxpython/xml/
grass-gxm.dtd menudata_modeler.xml module_items.xml wxgui_items.dtd
grass-gxw.dtd menudata_psmap.xml module_tree_menudata.xml wxgui_items.xml
main_menu.dtd menudata.README module_tree.xml
main_menu.xml menudata.xml toolboxes.dtd
menudata.dtd module_items.dtd toolboxes.xml
- G6.4.3. and its gui can be properly launched (no problems like mentioned in point 1). So here I tried to install add.ons. There I ran g.extension from the grass terminal but face following problem:
GRASS 6.4.3 (gisdemo_ncspm):~ > g.extension extension=r.stream.order
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)…
WARNING: gnome-keyring:: couldn’t connect to: /tmp/keyring-U4bRKD/pkcs11: No such file or directory
A r.stream.order/main.c
A r.stream.order/description.html
A r.stream.order/global.h
A r.stream.order/io.c
A r.stream.order/r_stream_order_orders.png
A r.stream.order/order.c
A r.stream.order/Makefile
U r.stream.order
Checked out revision 57991.
Compiling <r.stream.order>…
Makefile:12: /usr/lib/grass64/include/Make/Module.make: No such file or directory
make: *** No rule to make target `/usr/lib/grass64/include/Make/Module.make’. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
I cannot add anything to the other problem but it might be similar to the recent problem on Suse:
Suse 12.3, GRASS 6.4.3 - addons not possible to install (http://permalink.gmane.org/gmane.comp.gis.grass.user/48209)
So does anyone have an idea what may cause the problems. I don’t think that the problems are related nor are they caused by my Xubuntu-Virtualbox setup. Do I miss any modules/packages/software that I need to install prior to grass? Or do I need to use different ppas for installing grass? Any help is of course mostly welcome!
Both seems like a GRASS problem, particularly, compilation/packaging problem, so there probably nothing you can do on you machine except for checking files:
/pathtograss7/etc/gui/wxpython/xml/menudata.xml for GRASS 7
/usr/lib/grass64/include/Make/Module.make for GRASS 6 (above says ‘no such file’ already)
Vaclav
Best regards,
Johannes
grass-user mailing list
grass-user@lists.osgeo.org
