And since my last build (today) I can't use properly the gcp gui, more
precisely I can't select a maps. When I launch the gcp gui (from the
console) and try to select a mapset, I have this error message :
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gcp/manager.py", line 390,
in OnLocation
self.cb_mapset.SetItems(self.mapsetList)
AttributeError: 'MapsetSelect' object has no attribute 'SetItems'
I don't know if it's a bug or a problem with my setup and I hope that I gave
enough information to help to eventually fix this.
It seems that this is more general bug in the GUI, because a similar
bug appears with r.proj and v.proj, probably caused by recent changes
to gui/wxpython/gui_core/gselect.py
Markus M
Thanks
Ahmadou H. DICKO
statistician economist (Ingénieur Statisticien Économiste)
PhD candidate in Climate change economics
Faculty of economics and managment - Cheikh Anta Diop University
West African Science Service Center on Climate Change and Adaptated Land Use
(WASCAL)
Center for Development Research (ZEF) - University of Bonn
email : ahmadou.dicko@ucad.edu.sn
twitter : @dickoah
github : github/dickoa
tel : +221 33 827 55 16
portable: +221 77 123 81 69
2014/1/10 Markus Metz <markus.metz.giswork@gmail.com>:
right, this widget has been changed to accept multiple values. I will
fix reported issue ASAP. Sorry for inconvenience. Martin
Thank you very much Martin.
I tried and it works but I have to copy the image I want to rectify to the
PERMANENT mapset
For some reason I cannot choose other mapset than the PERMANENT at the
'create or edit imagery group' window.
are you speaking about first page of the wizard. It's working for me.
Does your source location contain really more mapsets.
On Mon, Jan 13, 2014 at 8:15 AM, Martin Landa <landa.martin@gmail.com>wrote:
2014/1/13 Markus Metz <markus.metz.giswork@gmail.com>:
> On Sun, Jan 12, 2014 at 12:10 PM, Martin Landa <landa.martin@gmail.com>
wrote:
>> Hi,
>> 2014/1/12 Markus Metz <markus.metz.giswork@gmail.com>:
>>> The GUI for [r|v].ptoj is still not working: the list of mapsets does
>>> not match the selected location.
>> thanks for reminder, should be fixed r58679. Anyway this part of
>> forms.py needs to be complete rewriten using signals.
> The GUI for [r|v].proj is still not working: the list of mapsets is
> now correct, but the list of raster maps is wrong.
the problem is that this part of form.py need to be rewritten for
which I do not have time at this moment. Should be hopefully fixed in
r58701.
The truth is that the whole forms needs to be rewritten and also parser
mechanism needs some improvements in the future and this should be
considered when rewriting forms. So, I'm not sure who and when is going to
do more than small improvements. I noted that there were some efforts
considering the parser...
Ahmadou H. DICKO
West African Science Service Center on Climate Change and Adaptated Land Use (WASCAL)
twitter : @dickoah
I tried and it works but I have to copy the image I want to rectify to the PERMANENT mapset
For some reason I cannot choose other mapset than the PERMANENT at the ‘create or edit imagery group’ window.
Ahmadou H. DICKO
twitter : @dickoah
PERMANENT mapset
are you speaking about first page of the wizard. It’s working for me.
Ahmadou H. DICKO
twitter : @dickoah
