On Wed, Jun 12, 2019 at 10:49 AM Helmut Kudrnovsky <hellik@web.de> wrote:
PyCharm is a nice python IDE.
anyone some experiences to share how to integrate GRASS python (pygrass and
grass script) into the PyCharm IDE environment?
Please add your notes also here then:
https://grasswiki.osgeo.org/wiki/Tools_for_Python_programming#PyCharm_IDE
thanks
Or, if PyCharm allows you to supply custom executable and parameters script execution, you can try to set it up with grass ... --exec
. The drawback is that debugger may not support that.
Alternatively, as a combination of both, you can set up a shortcut for “PyCharm with GRASS GIS” using grass --tmp-location XY --exec pycharm
. In that case, as in case with running it inside, some Python version/packages issues may arise more likely.
Best,
Vaclav
Vaclav
