[GRASS-dev] [GRASS-user] Keeping GRASS/OTB/... algorithm in qgis processing
On 05/02/18 12:40, Helmut Kudrnovsky wrote:
Dear GRASS GIS community,
herewith I may bring a discussion on QGIS dev ML about how to proceed with
maintaining GRASS, OTB and other algorithms in qgis processing to your
attention.
http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-Keeping-OTB-algorithm-in-qgis-processing-td5352056.html
it seems that a shared attempt may be needed for a long-term, sustainable
solution.
citing here my post in that thread:
https://lists.osgeo.org/pipermail/qgis-developer/2018-February/051892.html
Otherwise if we don't care and just want to enable others to have QGIS
intgration, they'll have to adopt the plugins. That might work better if
there
is real interest. But I think they usally prefer their tools to be used in
their own environment and don't care that much about whether it works in
QGIS
<or not. Is there solid interest of the SAGA or GRASS team to adopt the
providers? Otherwise I guess they'll sooner or later will die.
quickly screened the GRASS MLs, I can't find any entry that the GRASS
community was ever asked if there could be e.g. a shared attempt for an
automatization to create/maintain the plugin code.
Looking at the new OSGeo website:
*Desktop Applications*
-QGIS Desktop
-GRASS GIS
*Geospatial Libraries*
-Orfeo ToolBox
-GDAL/OGR
*Meta CRS Initiative*
-PROJ4
Most of the software mentioned in this thread are projects under the common
umbrella of OSGeo.
An option may be to ask that OSGeo plays a more proactive role in helping to
coordinate and supporting (technically/financally/...) such inter-project
challenges.
I will forward a short summary of this thread to the GRASS community.
contributions of ideas/support/technical solutions/... are very welcome.
The debate is about whether the access to outside tools (i.e. the 'providers') should be kept within the QGIS core code, or whether this should be externalized to plugins, with the hope that others (the respective software teams ? users ?) take over the maintenance of these plugins.
GRASS seems to be seen as something of a border case, also because of the existing tight (C++ level) linkage between the two through the grass plugin.
One suggestion coming from Rashad (OTB team) seems to be to leave the core part of the providers in the QGIS core code (in the idea that that would ensure that they would be kept up to date together with the core code), but to leave it up to the respective teams to provide the algorithm descriptions. But I didn't have the feeling that the QGIS team was up to that...
I don't know how difficult it would be to create such algorithm descriptions automagically.
Moritz
Von: "Moritz Lennert"
https://github.com/qgis/QGIS/search?p=1&q=processing+grass&type=&utf8=✓
AFAIU there are some general python scripts to provide it in processing:
e.g.
python/plugins/processing/algs/grass7/Grass7AlgorithmProvider.py
and there are a lot of txt files providing the module interface
e.g
python/plugins/processing/algs/grass7/description/r.out.png.txt
Export a GRASS raster map as a non-georeferenced PNG image
Raster (r.*)
QgsProcessingParameterRasterLayer|input|Input raster|None|False
QgsProcessingParameterNumber|compression|Compression level of PNG file (0 = none, 1 = fastest, 9 = best)|QgsProcessingParameterNumber.Integer|6|True|0|9
and other files
kind regards
Helmut
for a better overview:
processing module description:
https://github.com/qgis/QGIS/tree/9fb386ac60f5e3155294b712ed064ad97eba3226/python/plugins/processing/algs/grass7/description
and related python helper scripts for more complex GRASS modules:
https://github.com/qgis/QGIS/tree/9fb386ac60f5e3155294b712ed064ad97eba3226/python/plugins/processing/algs/grass7/ext
Helmut
e.g.
No, this is the provider itself, not a tool to create the descriptions.
e.g
Raster (r.*)
and other files
My question was whether it would be possible to create these description files more or less automagically.
I think the python scripts for more complex operations have to be created manually.
IIUC (from rapid reading of the threads on the qgis-developer list), Rashad's suggestion was to keep the *AlgorithmProvider code in the QGIS code base, but to possibly move the creation of the description and script files to a plugin managed outside QGIS core, possibly by the respective external software teams.
Moritz
On Mon, Feb 5, 2018 at 2:49 PM, Moritz Lennert <mlennert@club.worldonline.be
&type=&utf8=%E2%9C%93
e.g.
e.g
Raster (r.*)
and other files
manually.
Yes. your are right on track! the idea is external tools (processing
providers) manage descriptor files in a format requested by qgis
processing.
I see already name-of-grass-module --interface-descriptor which gives an
xml for GRASS gui.
what qgis want is a csv in a specific format. The contents of qgis
descriptor seems much less compared to --interface-descriptor.
Correct me if I am wrong, --interface-descriptor is available in all grass
modules. So maybe a --qgis can do the work.
This has some advantages.
* GRASS developers are free to fix parameter name, parameter description,
list of modules(add and remove) changes without affecting qgis.
* grass 7.5 has 10 modules and grass 7.9 can have 15 and same QGIS will
work.
* QGIS will not need to maintain these files and keep updating/adding new
modules with their release process. whatever is generated from a grass
build/install have better integration with qgis
* Finally this descriptors for qgis are generated with a makefile target
that allows users and packagers to include it.
* QGIS can use multiple version of grass by changing install prefix because
descriptors are *always* found in a directory relative to install prefix.
QGIS provider will be like:
I picked a descriptor file
parse and make the ui,
take input and execute whatever program the descriptor is to run.
QGIS already manages parsing of parameters and running them. So for
providers who wish to be integrated in qgis will deal with a descriptor
file and things go fine.
Having a single interface to launch all or most of toolboxes (willing to
contribute descriptor with installation) can have same way of execution. At
that point, QGIS should consider
adding some generic code in provider and avoid plugins for such toolboxes.
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
   Rashad
On 05/02/18 17:06, Rashad Kanavath wrote:
On Mon, Feb 5, 2018 at 2:49 PM, Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
        <https://github.com/qgis/QGIS/search?p=1&q=processing+grass&type=&utf8=✓&gt;
        processing:
        e.g.
        e.g
        Raster (r.*)
        and other files
    created manually.
Yes. your are right on track! the idea is external tools (processing providers) manage descriptor files in a format requested by qgis processing.
I see already name-of-grass-module --interface-descriptor which gives an xml for GRASS gui.
what qgis want is a csv in a specific format. The contents of qgis descriptor seems much less compared to --interface-descriptor.
Correct me if I am wrong, --interface-descriptor is available in all grass modules. So maybe a --qgis can do the work.
Yes, this is what I was aiming at.
* GRASS developers are free to fix parameter name, parameter description, list of modules(add and remove) changes without affecting qgis.
* grass 7.5 has 10 modules and grass 7.9 can have 15 and same QGIS will work.
* QGIS will not need to maintain these files and keep updating/adding new modules with their release process. whatever is generated from a grass build/install have better integration with qgis
* Finally this descriptors for qgis are generated with a makefile target that allows users and packagers to include it.
* QGIS can use multiple version of grass by changing install prefix because descriptors are *always* found in a directory relative to install prefix.
QGIS already manages parsing of parameters and running them. So for providers who wish to be integrated in qgis will deal with a descriptor file and things go fine.
Having a single interface to launch all or most of toolboxes (willing to contribute descriptor with installation) can have same way of execution. At that point, QGIS should consider
Thanks for the explanation / confirmation, Rashad.
Now, the question is whether this is in line with the ideas of the QGIS developers...
Moritz
In general I would say that both sides (QGIS – GRASS) benefit from an integration like Processing or the GRASS plugin. QGIS gains algorithms, GRASS gains user base. And for the future, Rashads and Moritz proposal make indeed a lot of sense!
The text descriptor files have been a real pain for maintaining interfaces for GRASS integration in Processing as well as the GRASS plugin. In addition, they make usage of AddOns practically impossible for most of the QGIS users.
However, for QGIS (and this is true for both integrations), the module UI was deliberately simplified by hiding / removing “advanced” option or splitting modules into “sub-types”. In addition not all modules could be meaningful added to the two QGIS integrations (e.g. temporal modules in Processing). And finally, some require extra work on the QGIS side (like r.mapcalc).
So, I would assume that a --qgis-descriptor solution would be most appropriate. But that would still require additional work (beyond implementing a parser solution) if the principles for the GRASS module UI in QGIS should stay as it is, like:
  • Tagging options and flags as advanced or basic/main/common (could be an opportunity to consolidate terminology in the module UI in GRASS as well)
  • Deciding which modules to use / exclude from QGIS (and how to mark them)
Maybe also Ondrejs work could be useful here : https://trac.osgeo.org/grass/wiki/GSoC/2016/PyQtGUI ?
Stefan
On Mon, Feb 5, 2018 at 2:49 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Von: “Moritz Lennert”
I don’t know how difficult it would be to create such algorithm
https://github.com/qgis/QGIS/search?p=1&q=processing+grass&type=&utf8=%E2%9C%93
e.g.
e.g
Raster (r.*)
and other files
IIUC (from rapid reading of the threads on the qgis-developer list), Rashad’s suggestion was to keep the *AlgorithmProvider code in the QGIS code base, but to possibly move the creation of the description and script files to a plugin managed outside QGIS core, possibly by the respective external software teams.
  • GRASS developers are free to fix parameter name, parameter description, list of modules(add and remove) changes without affecting qgis.
  • grass 7.5 has 10 modules and grass 7.9 can have 15 and same QGIS will work.
  • QGIS will not need to maintain these files and keep updating/adding new modules with their release process. whatever is generated from a grass build/install have better integration with qgis
  • Finally this descriptors for qgis are generated with a makefile target that allows users and packagers to include it.
  • QGIS can use multiple version of grass by changing install prefix because descriptors are always found in a directory relative to install prefix.
Moritz
Rashad
Dear all,
I’m answering here rather than the “[GRASS-dev] External providers in QGIS” thread since here we have the technical discussion already. I’m also removing grass-user list.
On Mon, Feb 5, 2018 at 3:56 PM, Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
There were already suggestions to change it in the past to something based on “–interface-description”, but it always hit various issues like those things you mention below. However, I think that it is exactly what needs to be done in any case because only that is sustainable and potentially also reusable by other tools (besides QGIS). The reuse is quite interesting also in the relation to the automatic import, export and temporary location (in context of --exec or grass_session).
Here the question is how important it is to do (keep) this or if perhaps different solution would give better result. For example, splitting (in the QGIS interface) r.slope.aspect to r.slope and r.aspect (and more) makes it slower for the user to compute slope and aspect - 2x filling the form and 2x loading input data. Reorganization of r.slope.aspect interface may result in more convenient form and shorter computation than the “r.slope + r.aspect” solution.
I think there needs to be a white list or back list. It seems analogous to the “toolboxes” for wxGUI. All r3.* and t.* modules are out for QGIS, but I think the rest needs to be hand picked. The limitation of the hand picking is that it does not work for addons and custom modules in general.
We should address this ASAP in the process. Besides r.mapcalc, it is esp. modules which output list of maps which are either time series (e.g. r.sim.water with -t) or multiple results (e.g. r.texture method=asm,var output=basename). (There is a discussion about this somewhere on the list.) I’m not sure what is the current solution for i.* which take a group, perhaps a list or a multiband file is good (?). In relation that, t.* and r3.* modules could take and output a list of maps (multiband) as well.
It can be “m.odule.name --qgis-descriptor” or “g.get.interface module=m.odule.name format=qgis” which can take the general (or generalized) --interface-description and transform it to what the processing adapter tool needs (or it can be just part of the adapter).
We already have the sections and also required parameters marked (in GUI), so the question is why it is not enough. Perhaps just fixing that is enough (for example description for each group). But of course if we say that the requirement for QGIS alg is that there is less than 5 options and no flags, then we need some additional system.
I think one of the challenges brought up in the past was GRASS terminology versus QGIS terminology. We don’t have a comparison table for that, but we have one for ArcGIS [1] and there are some obvious things like “vector map” versus “vector layer” and than GRASS’ “layer of vector map”.
I can see 3 solutions: 1) ignore the differences, 2) come up with different names (I think we have been there already), or 3) have a special description field which is QGIS-friendly or OGC glossary compliant if needed.
[1] https://grasswiki.osgeo.org/wiki/Terminology_comparison_between_ArcGIS_and_GRASS_GIS
We have the “toolbox” mechanism to populate things in wxGUI, so the files can be reused to create algorithm tree for QGIS. One needs to add the modules there explicitly and then additionally find addons, but we do that for wxGUI now.
Yes, for the QGIS GRASS plugin. I’m not sure how much the plugin is part of this discussion. Not long ago, Radim worked on it a lot. Ondrej’s work is aimed at what the C++ plugin is aimed at and what wxGUI is aimed at - i.e. it’s a Qt interface to GRASS which could be used in GRASS or as QGIS plugin. I don’t think it is useful for the processing part, but it is a good prototype to start from. Currently it misses a lot of features, it is basically limited reimplementation of gui/…/forms.py. There is also some raster rendering work from Soeren which is parallel to the C++/C part of the QGIS GRASS plugin.
Best,
Vaclav
Stefan
From: grass-dev [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of Rashad Kanavath
Sent: mandag 5. februar 2018 17.06
To: Moritz Lennert <mlennert@club.worldonline.be>
Cc: grass-user@lists.osgeo.org; grass-dev@lists.osgeo.org; Helmut Kudrnovsky <hellik@web.de>
Subject: Re: [GRASS-dev] [GRASS-user] Keeping GRASS/OTB/… algorithm in qgis processing
e.g.
e.g
Raster (r.*)
and other files
Moritz
Rashad
grass-user mailing list
Hello,
On Wed, Feb 7, 2018 at 12:32 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Dear all,
OTB also suffers from this issue in QGIS. We are solving it with new updates to processing provider. Maybe grass could reuse it!. Currently, I have two blocking issues.
  1. QGIS batch processing that demands a table with each row representing a single execution of algorithm.
  2. https://github.com/qgis/QGIS/pull/6272
standard processing dialog and qgis graphical modeler works after pull request (pending merge)
For OTB, my initial thought is to disable batch processing and later work on this part. It is important to have two of them working than none of them.
QGIS’s proposition earlier was to split application which I don’t think is something right to do here.
Since grass also has similar issues, I prefer QGIS would accept fixes.
If there is an executable or algorithm found in a gis provider, it can ask what should I do? And the provider can answer run some program with so and so argument(s).
In case of otb, there will be a dedicated executable to deal with. IIUC grass can say, if you have an algorithm in a directory (listed in provider, could be relative to install prefix of GRASS),
run <module_name> --qgis-descriptor. With this, a user installing an addon will have to do nothing to make it work with qgis.
ofcourse, once qgis found a descriptor file for an algorithm, it won’t bother ask provider what to do again or next run. Because it can read this file and run algorithm.
The above “template” of identifying a QGIS provider algorithm can be generic and reused in different providers.
If there is question of “trusting” on running apps in a given directory, that is something debatable.
Rashad
Best,
Vaclav
Stefan
e.g.
e.g
Raster (r.*)
and other files
Moritz
Rashad
