any chance that you update to the much more modern GRASS GIS 7.8?
Best
On Thu, Jan 9, 2020 at 6:05 PM Frank David <frank.david@geophom.fr> wrote:
Hello all,
I have no more gui on grass 7.6 after upgrade from debian strech to buster.
Thank you for your help !
Regards
Frank
See below last errors :
File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 169, in <module>
sys.exit(main())
File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 156, in main
app = GMApp(workspaceFile)
File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 50, in __init__
wx.App.__init__(self, False)
File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line 8628, in __init__
self._BootstrapApp()
File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py", line 8196, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/usr/local/grass-7.6.0/gui/wxpython/wxgui.py", line 103, in OnInit
workspace=self.workspaceFile)
File "/usr/local/grass-7.6.0/gui/wxpython/lmgr/frame.py", line 142, in __init__
self.notebook = self._createNoteBook()
File "/usr/local/grass-7.6.0/gui/wxpython/lmgr/frame.py", line 337, in _createNoteBook
gcstyle=GC_PROMPT)
File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/goutput.py", line 118, in __init__
self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 139, in __init__
GPrompt.__init__(self, parent=parent, menuModel=menuModel)
File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 57, in __init__
self.mapList = self._getListOfMaps()
File "/usr/local/grass-7.6.0/gui/wxpython/gui_core/prompt.py", line 101, in _getListOfMaps
result['raster'] = grass.list_strings('raster')
File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 1252, in list_strings
mapset=mapset).splitlines():
File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 478, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File "/usr/local/grass-7.6.0/etc/python/grass/script/core.py", line 334, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.list', '--q', '-m', 'type=raster'] ended with error
Process ended with non-zero return code 127. See errors in the (error) output.
Error in atexit._run_exitfuncs:
File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
func(*targs, **kargs)
PyAssertionError: C++ assertion "GetEventHandler() == this" failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed
Error in sys.exitfunc:
wx._core.PyAssertionError: C++ assertion "GetEventHandler() == this" failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed--
grass-user mailing list
grass-user@lists.osgeo.org
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
