it's not enough. You need to defined also categories for layer '2',
see `v.category` for details. This module allows to change layer
number, but unfortunately not to copy categories from one layer to
another.
another.
So, if I need to assign different attributes to the objects in the vector
file I need to assign new categories to the objects and store them in a new
layer to be connected to a different table.
But how can I add a new layer to a vector?
v.category seems to produce a new vector map with new category values but
doesn't add a new layer in the input map.
Sure it does. v.category op=add layer=2 ... will create a new map with the old category values preserved in layer 1 and with new category values in layer 2. And as mentioned in a previous mail, in GRASS7 you can simply copy the category values of layer 1 to layer 2 with op=transfer.
But I suppose there is another simpler way to add and fill a new layer as,
for example, to reclass the category numbers of a map and put the reclassed
categories in a new layer to be connected to a new table with new
attributes. Or not?
AFAIK, v.reclass does not allow you to chose the layer of categories in the new map, only which layer to use in the old map.
On Sat, Nov 24, 2012 at 11:31 AM, Moritz Lennert
I start to like this function (hint hint
I quickly compared the two main files and it doesn't look like
complicated to backport.
However, I cannot judge if it would have any background complications.
Dear Martin and Moritz,
thanks for the helpful explanations.
So a layer is a set of integer numerical value (categories) assigned to
objects in a vector geometry file that can be used to assign to the objects
the attributes that have the same category numbers in a connected table.
The only way I know and I used some times ago, is through v.db.addtable
that allow to create an empty new table connected to an existing vector and
to define the pertaining new layer. Then I enter v.digit and assign new
category values to the objects in the map through the new layer and fill the
new table with other attributes.
attributes. Or not?
Aldo Clerici
-----Messaggio originale-----
Da: Martin Landa [mailto:landa.martin@gmail.com]
Inviato: mercoledì 21 novembre 2012 15:55
A: Moritz Lennert
Cc: grass-user@lists.osgeo.org; Aldo Clerici; GRASS developers list
Oggetto: Re: [GRASS-dev] [GRASS-user] Problems in adding tables to a map
2012/11/21 Moritz Lennert <mlennert@club.worldonline.be>:
Already exists in grass7: option=transfer
ops, I was accidentally checking 6.5. Too many versions installed Thanks
for the correction.
