On Tue, Jan 7, 2014 at 7:43 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
>(which I really actually need, i.landsat.dehaze)
have a look at
http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6
and
http://grasswiki.osgeo.org/wiki/AddOns/GRASS_7/imagery
https://svn.osgeo.org/grass/grass-addons/grass7/imagery/i.landsat.dehaze seems to be available only for grass6 at the moment (?),
maybe the author (cc'ed) has more insight about this.> In this case, I am just forcing the error by trying to install an
> extensionbeside addon availability, "Settings -> Addons extensions -> Install
extensions from addons" isn't working in winGRASS7.only the the command line version of g.extension is working, e.g.:
g.extension extension=r.geomorphon operation=add
Downloading precompiled GRASS Addons <r.geomorphon>...
Updating metadata file...
Installation of <r.geomorphon> successfully finished
(Tue Jan 07 13:41:31 2014) Command finished (2 sec)please open a ticket in http://trac.osgeo.org/grass/
this can be again the Python incompatibility issue (the MAXREPEAT problem).
For this issue there is already ticket
http://trac.osgeo.org/grass/ticket/2150
It usually appears when you have also ArcGIS installed.
Anna
best regards
Helmut
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Python-error-with-GRASS-7-on-Windows-8-tp5096508p5096756.html
grass-user mailing list
grass-user@lists.osgeo.org
