On 22/10/18 06:02, kameswari devi wrote:
Hello all,
I m trying to use Create_iwave.py for template creation in grass for
atmopsheric correction.But due to the spectral response values errors
are thrown. here i am sending the rsr i used and error i got .please
suggest me. thakn you
wav(nm) B10
477 0.3744
478 0.6864
480 1
481 0.8624
482 0.6018
483 0.4434
484
485
486 0.377
487 0.667
488 0.968
489 1
490 0.760
491 0.590
492 0.455
AFAIR, you need to separate fields by a comma, not a space.
Moritz
Please keep discussions on the mailing list.
On 22/10/18 13:07, kameswari devi wrote:
yes i have given a csv file but x_new is above the interpolation range
message is appeared.
wav(nm),B10,B11
477,0.3744
478,0.6864
480,1
481,0.8624
482,0.6018
483,0.4434
484,
485,
486,0.377
487,0.667
488,0.968
489,1
490,0.760
491,0.590
492,0.455
AFAIK, you always need the same number of fields on every line, but the first 8 lines only have two fields while the rest has 3 fields.
Moritz
On Mon, Oct 22, 2018 at 1:32 PM Moritz Lennert
Hello all,
wav(nm) B10
477 0.3744
478 0.6864
480 1
481 0.8624
482 0.6018
483 0.4434
484
485
486 0.377
487 0.667
488 0.968
489 1
490 0.760
491 0.590
492 0.455
Moritz
On Mon, Oct 22, 2018 at 1:32 PM Moritz Lennert <mlennert@club.worldonline.be> wrote:
wav(nm),B10,B11
477,0.3744
478,0.6864
480,1
481,0.8624
482,0.6018
483,0.4434
484,
485,
486,0.377
487,0.667
488,0.968
489,1
490,0.760
491,0.590
492,0.455
Which GRASS version are you using? Please use a recent GRASS 7.4 version, or better GRASS 7.6. Can you also post the full output of create_iwave.py? That could help to find out what goes wrong.
Markus M
Moritz
Hello all,
wav(nm) B10
477 0.3744
478 0.6864
480 1
481 0.8624
482 0.6018
483 0.4434
484
485
486 0.377
487 0.667
488 0.968
489 1
490 0.760
491 0.590
492 0.455
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
