[GRASS-dev] [GRASS-user] RE : RE : Merge polygone with same attribut of a shapefile
Nikos Alexandris wrote:
# get stats for cats in layer 2, that is for all different cats!
v.rast.stats -c vector=polygons_tmp raster=RandomRaster column_prefix=rr2
layer=2
#...unfortunately, this last step in uploading stats in to layer 2, fails in
G7 :frowning:
e.g.
v.rast.stats -c -e vector=polygons_tmp layer=2 raster=RandomRaster
colprefix=ee
Processing data (1 categories)...
Updating the database ...
DBMI-SQLite driver error:
Error in sqlite3_prepare():
no such column: ee_n
ERROR: Error while executing: 'UPDATE polygons_tmp_polygons_2 SET ee_n=196
       , ee_min=10 , ee_max=99 , ee_range=89 , ee_mean=53.8571428571429 ,
       ee_stddev=26.0770052744105 , ee_variance=680.010204081633 ,
       ee_cf_var=48.4188426845818 , ee_sum=10556 , ee_first_quartile=29 ,
       ee_median=54 , ee_third_quartile=76 , ee_percentile_90=90 WHERE
       cat=1'
WARNING: Failed to upload statistics to attribute table of vector map
         <polygons_tmp>.
I think it wrongly look in/for layer=1 ? The "Processing data (1
categories)..." is the suspect because:
# layer=2 contains...
v.db.select polygons_tmp layer=2 col=cat
cat
1
2
# and layer=1 contains
v.db.select polygons_tmp col=cat
cat
1
A bug?
Nikos
# it works in G64! -- note different parameter naming: "colprefix="
v.build polygons_tmp
v.rast.stats -c vector=polygons_tmp layer=2 raster=RandomRaster
colprefix=rr2
layer=2
G7 :frowning:
e.g.
colprefix=ee
        cat=1'
          <polygons_tmp>.
cat
1
2
cat
1
A bug?
v.db.addcolumn seems to lack the layer option here:
https://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.rast.stats/v.rast.stats.py#L194
Try to add it in the script and see if that makes it work.
Moritz
>> layer=2
>> in G7 :frowning:
.stats.py#L194
Indeed. Milles Mercis, N
ps- Care for a diff? Or already changed?
layer=2
in G7 :frowning:
.stats.py#L194
I just committed a fix. Please test to see if it works.
Moritz
Moritz:
Works fine, thnx.
N
