[GRASS-dev] [GRASS-user] temporary files of grass.script.array
Johannes Radinger wrote:
In GRASS 7 (RC1) python it is possible to export a raster map to an array
which can be used e.g. by Numpy.
For example:
import grass.script.array as garray
x1 = garray.array()
x1.read("my_raster")
It seems that this creates a temporary file in the .tmp folder of the
respective
location. I am not sure if this has been existing before, but these
temporary
files are not deleted after e.g. x1 is not used anymore (i.e. the
calculation of
the script finished). So do I need to manually (in the python script) close
that x1 so
that the associated temporary file gets deleted (and if yes how?)? Otherwise
when using this procedure to do numpy calculations in loops the tmp-files
pile up quite fast.
Of course I can empty the tmp folder after every loop, but I am not sure
if this is really the right way.
The temporary files were supposed to be deleted when the array object
was destroyed. However, this relied upon the ._close() method, which
is no longer used. r64426 (trunk) should fix this.
Apart from that, you can manually delete the temporary file for an
array object with e.g. grass.script.try_remove(x1.filename).
On Tue, Feb 3, 2015 at 4:23 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
Please let me know if that should be backported then.
I just tested in trunk, and it works: The temporary file that is create
when assigning a raster to an python array is deleted once e.g.
the python session is closed again. So this would be a nice
thing also to have implemented in the next RC of GRASS7.
/johannes
ยทยทยท
