[GRASS-dev] [GRASS-user] unexpected i.pansharpen results
I can transform maps to float or DCELL with both the Brovey and PCA methods. However, this doesn’t seem possible with the IHS method. i.rgb.ihs outputs CELL maps even if the inputs are float. Any suggestions?
Michael
On Thu, Jan 31, 2013 at 1:52 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
On Thu, Jan 31, 2013 at 7:06 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
i.pansharpen uses Python, not Bash. So it is not an integer math problem.
But it calls r.mapcalc, e.g. in lines 151-153. If k is integer and not
float, r.mapcalc will do integer division. Equivalent for lines 159,
162, 165. This could be fixed by casting the numerator to double with
double().
Markus M
However, you might try changing your input maps to float or DCELL. See if that changes things.
Michael
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Jan 31, 2013, at 2:11 AM, <grass-user-request@lists.osgeo.org>
wrote:
Subject: Re: [GRASS-user] unexpected i.pansharpen results
Date: January 31, 2013 2:11:33 AM MST
To: Hamish <hamish_b@yahoo.com>
Cc: GRASS user list <grass-user@lists.osgeo.org>
hmmm, yes that looks like an old friend to check…
On 31 January 2013 14:06, Hamish <hamish_b@yahoo.com> wrote:
(sorry for the html,top posting)
I wonder if the script is doing integer division when it should be doing floating point division?
http://trac.osgeo.org/grass/browser/grass/trunk/scripts/i.pansharpen/i.pansharpen.py
Hamish
— On Wed, 1/30/13, Eric Goddard <egoddard1010@gmail.com> wrote:
Subject: [GRASS-user] unexpected i.pansharpen results
To: grass-user@lists.osgeo.org
Date: Wednesday, January 30, 2013, 8:30 AM
I’m attempting to pansharpen some ikonos imagery using the i.pansharpen tool in Grass7 on windows 7 installed via OSGeo4W (r54756-478). The range for the sharpened red, green, and blue outputs are 0-30, which seems suspicious given the 16bit range of the input bands. The command I used was:
i.pansharpen.py “sharpen=ihs” “ms3=ik_mss.4@eric” “ms2=ik_mss.3@eric” “ms1=ik_mss.2@eric” “pan=ik_pan@eric” “output_prefix=ik_ihs”
The input bands are linked via r.external, would that matter?
The output from my test area is below. Any assistance would be greatly appreciated.<image.png>
Eric
-----Inline Attachment Follows-----
grass-user mailing list
