[GRASS-dev] [GRASS-user] Using r.out.kml and scripts in Windows Binary- error
2012/9/13 Martin Landa <landa.martin@gmail.com>:
have you tried to install extension from command line or wxGUI [1]?
wxGUI uses another g.extension (Python based) which should download on
Windows directly prepared binaries.
to avoid user confusion, probably bash script `g.extension` should end
on Windows with an error, eg.
"g.extension is not working on MS Windows. Use wxGUI Extension Manager instead."
or similar...
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
