[GRASS-dev] grass + vtk , which vtk version
Hi All,
i'm intersted to use the vtk-grass-bridge [1] ,
i've few questins about it .
Can i use the latest stable release : VTK - 5.6
instead of the suggested version ( VTK - 5.4) ?
... have you any clue if this beatifull work will be "ported" to run under grass6.x ?
thanks!
Massimo.
[1] http://code.google.com/p/vtk-grass-bridge/
Hello Massimo,
i'm the developer of the vtk-grass-bridge, you can write any questions
about the project directly to me. :slight_smile:
2010/8/19 Massimo Di Stefano <massimodisasha@gmail.com>:
Hi All,
It is fully compatible.
Unfortunately, i do not have the time to support booth versions of
grass, so grass7 is the only option.
Please notice the vtk-grass-bridge is a work in progress and not
stable enough to be used in production environments. There is also a
massive lack of examples, tutorials and documentation. Only the source
code is partly well documented.
But feel free to try it out and don't bother to ask any questions.
Best regards
Soeren
thanks!
Massimo.
[1] http://code.google.com/p/vtk-grass-bridge/_______________________________________________
grass-dev mailing list
grass-dev@lists.osgeo.org
