[GRASS-dev] [GRASS-windows] Re: Build GRASS with MySQL support enabled
I'm forwarding from GRASS-Windows; I tried to build GRASS with MySQL support enabled, using prebuilt binaries for Windows from official MySQL web site (http://dev.mysql.com/downloads/mysql/5.0.html#win32; without installer zip)
configure worked (I only needed to rename libmysql.dll to libmysqlclient.dll and place mysql_config in /usr/local/bin) but make failed;
I attacched the error output messages as a txt file;
Thanks in advance for your help.
Marco
----- Original Message ----- From: "Marco Pasetti" <marcopstt@gmail.com>
To: "darren norris" <doon75@hotmail.com>; <grass-stats@lists.osgeo.org>
Cc: <grass-windows@lists.osgeo.org>
Sent: Wednesday, July 23, 2008 1:12 PM
Subject: Re: [GRASS-windows] Re: Build GRASS with MySQL support enabled
Hi Darren,
ok, after some tricks and trials, configure worked; now I'm compiling... I
hope it will work :slight_smile:
unfortunately it didn't work :frowning:
I attacched the error messages as a txt file; I hope that someone else could
help us.
Marco
grass-windows mailing list
http://lists.osgeo.org/mailman/listinfo/grass-windows
(attachments)
mysql-errors.txt (19.4 KB)
