[GRASS-dev] GRASS won't compile - can't 'find' gdal
I just tried to compile GRASS yesterday to catch up. It won’t get past configure, giving a gdal not found error.
I’m using a Mac with OS X 10.5 I’m using the same configuration string that worked a couple weeks back. I updated from source yesterday (GRASS 6.4 and 7 give the same results). To be on the safe side, after getting these errors, I updated my frameworks (including the gdal framework), from William Kyngesbury’s site. Same result.
William mentioned that other people have had similar issues. So, I’ve pasted in my configure string and configure output below and attached the config.log file. If anyone has suggestions I’ll try them out.
Thanks
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
(attachments)
config.log (17.7 KB)
I tried to compile grass on Macosx 10.4.11 (Tiger) today an got the same error message when running configure:
checking for gdal-config… /Library/Frameworks/GDAL.framework/Programs/gdal-config
configure: error: *** Unable to locate GDAL library.
The same happens with all versions of grass (i.e. grass-6.2.3, grass-6.3.0, grass-6.4.0RC2, grass-6.4.svn, grass-7.0.svn).
I attached the build script and the config.log to this mail, but the important part from the config.log should be the following:
gcc -o conftest -g -O2 -I/Library/Frameworks/GDAL.framework/Versions/1.5/Headers conftest.c -L/Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib -lgdal 1>&5
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld: warning can’t open dynamic library: @loader_path/Libraries/libogdi.dylib referenced from: /Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib/libgdal.dylib (checking for undefined symbols may be affected) (No such file or directory, errno = 2)
So there are problems with loading other libraries (not the gdal-library).
Has someone an idea why this goes wrong? I installed all frameworks needed from http://www.kyngchaos.com/software:grass/
Andreas.
(attachments)
config.log (26.3 KB)
custom_configure.sh (1.9 KB)
checking for gdal-config... /Library/Frameworks/GDAL.framework/Programs/gdal-config
The same happens with all versions of grass (i.e. grass-6.2.3, grass-6.3.0, grass-6.4.0RC2, grass-6.4.svn, grass-7.0.svn). I attached the build script and the config.log to this mail, but the important part from the config.log should be the following:
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld: warning can't open dynamic library: @loader_path/Libraries/libogdi.dylib referenced from:
The path to the ogdi library is not known to the system and must be included. gdalinfo --formats should also not work (or any other gdal utilities). I have the same problem under Linux if I don't include the path to the custom compiled ogdi library in the system-wide library path. Under Linux I create a new file named ogdi.conf under /etc/ld.so.conf.d/ with the path to the ogdi library in it, then it works, no idea about how to do it on a Mac.
I hope this points to the right direction.
Markus M
Andreas.
Am 06.07.2008 um 21:51 schrieb Michael Barton:
I just tried to compile GRASS yesterday to catch up. It won't get past configure, giving a gdal not found error.
I'm using a Mac with OS X 10.5 I'm using the same configuration string that worked a couple weeks back. I updated from source yesterday (GRASS 6.4 and 7 give the same results). To be on the safe side, after getting these errors, I updated my frameworks (including the gdal framework), from William Kyngesbury's site. Same result.
William mentioned that other people have had similar issues. So, I've pasted in my configure string and configure output below and attached the config.log file. If anyone has suggestions I'll try them out.
Thanks
Michael
____________________
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton <http://www.public.asu.edu/~cmbarton&gt;&gt;
<config.log>
=========== configure string and output ============
Last login: Sat Jul 5 18:26:18 on ttys000
cmb-MBP-2:~ cmbarton$ cd /Users/cmbarton/grass_dev/grass6_src cmb-MBP-2:grass6_src cmbarton$ export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
cmb-MBP-2:grass6_src cmbarton$ ./configure --with-freetype --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --without-postgres --without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-cxx --with-tcltk-includes=/usr/local/tcltk/include --with-tcltk-libs=/usr/local/tcltk/lib --with-x --without-motif --without-glw --with-opengl=x11 --with-opengl-libs=/usr/X11R6/lib --without-readline --prefix=/Applications/GRASS --enable-macosx-app --with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.7.1/bin/wx-config
checking host system type... i386-apple-darwin9.4.0
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... no
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /Users/cmbarton/grass_dev/grass6_src
checking for build directory... /Users/cmbarton/grass_dev/grass6_src
checking for MacOSX App... yes
checking how to build libraries... shared
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking if 64bit support is requested... no
checking if 64bit Sparc VIS support is requested... no
checking system version (for dynamic loading)... Darwin-9.4.0
checking for dlopen in -ldl... yes
checking for ar... ar
checking for additional include dirs... checking for additional library dirs... checking for a BSD compatible install... /usr/bin/install -c
checking for flex... flex
checking for yywrap in -lfl... yes
checking for bison... bison -y
checking for env... env
checking for perl... /usr/bin/perl
checking for ANSI C header files... yes
checking for limits.h... yes
checking for termio.h... no
checking for termios.h... yes
checking for unistd.h... yes
checking for values.h... no
checking for f2c.h... no
checking for g2c.h... no
checking for sys/ioctl.h... yes
checking for sys/mtio.h... yes
checking for sys/resource.h... yes
checking for sys/time.h... yes
checking for sys/timeb.h... yes
checking for sys/types.h... yes
checking for sys/utsname.h... yes
checking for libintl.h... no
checking for iconv.h... yes
checking for langinfo.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking for off_t... yes
checking for uid_t in sys/types.h... yes
checking return type of signal handlers... void
checking for ftime... yes
checking for gethostname... yes
checking for gettimeofday... yes
checking for lseek... yes
checking for nice... yes
checking for time... yes
checking for uname... yes
checking for seteuid... yes
checking for setpriority... yes
checking for setreuid... yes
checking for setruid... yes
checking for drand48... yes
checking for putenv... yes
checking for setenv... yes
checking for nanosleep... yes
checking whether setpgrp takes no argument... yes
checking for long long int... yes
checking for W11... no
checking for X... libraries /usr/X11/lib, headers /usr/X11/include
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking whether to use Curses... yes
checking for curses.h... yes
checking curses.h WINDOW structure component... _maxy
checking for initscr in -lncurses... yes
checking for keypad in -lncurses... yes
checking for gtty in -lcompat... no
checking for gtty in -lbsd-compat... no
checking for gtty in -lbsd... no
checking for library containing cuserid... no
checking for xdrmem_create... yes
checking for asprintf... yes
checking for atan... yes
checking for dlsym... yes
checking for iconv... no
checking for iconv in -liconv... yes
checking for socket... yes
checking for location of zlib includes... checking for zlib.h... yes
checking for location of zlib library... checking for deflate in -lz... yes
checking for location of External PROJ.4 includes... /Library/Frameworks/PROJ.framework/unix/include
checking for proj_api.h... yes
checking External PROJ.4 version... 460
checking for location of External PROJ.4 library... /Library/Frameworks/PROJ.framework/unix/lib
checking for pj_get_def in -lproj... yes
checking for location of External PROJ.4 data files... /Library/Frameworks/PROJ.framework/Resources/proj
checking for /Library/Frameworks/PROJ.framework/Resources/proj/epsg... yes
checking for nad2bin... /Library/Frameworks/PROJ.framework/Programs/nad2bin
checking whether to use Readline... no
checking whether to use JPEG... yes
checking for location of JPEG includes... /Library/Frameworks/UnixImageIO.framework/unix/include
checking for jpeglib.h... yes
checking for location of JPEG library... /Library/Frameworks/UnixImageIO.framework/unix/lib
checking for jpeg_start_compress in -ljpeg... yes
checking whether to use GDAL... yes
grass-dev mailing list
grass-dev@lists.osgeo.org <mailto:grass-dev@lists.osgeo.org>
/usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld: warning can't open dynamic library: @loader_path/Libraries/libogdi.dylib referenced from: /Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib/libgdal.dylib (checking for undefined symbols may be affected) (No such file or directory, errno = 2)
Which exact version of the GDAL framework do you have installed?
Does "gdalinfo --formats" work in a Terminal?
Try these exports before running configure:
export CFLAGS=-Os
export CXXFLAGS=-Os
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
thanks for your help. The hint about the ogdi library solved the problem for me.
It seems that the gdal-framework provided at www.kyngchaos.com needs these libraries but I hadn't them installed. First I tried to compile the ogdi library with these instructions for macosx:
(http://grass.itc.it/platforms/macgrass/ogdi.php) and (http://www.kyngchaos.com/macosx:build:ogdi)
But that didn't work - there were so much unresolved includes that I gave it up to compile ogdi.
What did the trick for me was compiling gdal by hand with the '--without-ogdi' configure-option (see http://www.kyngchaos.com/macosx:build:gdal ) as macosx framework.
Thanks again,
Andreas.
Am 19.01.2009 um 10:44 schrieb Markus Metz:
Markus M
Andreas.
Thanks
Michael
Phone: 480-965-6262
Fax: 480-965-7671
<config.log>
On Jan 19, 2009, at 9:49 AM, Andreas Hörsken wrote:
They are inside the GDAL framework bundle. That "@loader_path" is a relative reference to the "loading" binary, which should be GDAL. For some reason this isn't working from configure.
Those instructions are a bit out of date, though should be good for OGDI 3.1.6 (current stable). But I think much of the hackery isn't needed in OGDI 3.2 beta.
Unless you leave the other bundled stuff there from my packaged GDAL, you'll probably lose the GRASS and Postgres formats.
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
