Just starting again with GRASS, so this could be dumb error on my part. 6.2.0beta3 compiles OK (although I did not check any error logs), but upon entering a location and mapset I get the following error. I’m on SuSe 10.1.
Bill Baker, Univ. of Wyomg
Welcome to GRASS 6.2.0beta3 (2006)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter: exit
GRASS 6.2.0beta3 (rmnp):/home/bakerwl > Error in startup script: can’t read “monitor_zooms(1,1,n)”: no such variable
while executing
“lappend region $monitor_zooms($mon,1,$attr)”
(procedure “MapCanvas::currentzoom” line 13)
invoked from within
“MapCanvas::currentzoom $mon”
(procedure “MapCanvas::coordconv” line 23)
invoked from within
“MapCanvas::coordconv $mon”
(procedure “MapCanvas::create” line 68)
invoked from within
“MapCanvas::create”
(procedure “Gm::startmon” line 11)
invoked from within
“Gm::startmon”
(procedure “Gm::create” line 69)
invoked from within
“Gm::create”
(procedure “main” line 30)
invoked from within
“main $argc $argv”
(file “/usr/local/grass-6.2.0beta3/etc/gm/gm.tcl” line 522)
upon entering a location and mapset I get the following error. I'm on
SuSe 10.1.
GRASS 6.2.0beta3 (rmnp):/home/bakerwl > Error in startup script: can't
read "monitor_zooms(1,1,n)": no such variable
while executing
"lappend region $monitor_zooms($mon,1,$attr)"
(procedure "MapCanvas::currentzoom" line 13)
invoked from within
"MapCanvas::currentzoom $mon"
(procedure "MapCanvas::coordconv" line 23)
invoked from within
"MapCanvas::coordconv $mon"
(procedure "MapCanvas::create" line 68)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 69)
invoked from within
"Gm::create"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.2.0beta3/etc/gm/gm.tcl" line 522)
