[GRASS-dev] GRASS6.4 Ptyhon scripts- module
Greetings
I was developing a special import script (for a designated dataset) and I used r.in.aster Python Script (GRASS7) as a based for this Python script in GRASS6.4.. It compiled but I got this error:
make: Entering directory `/home/anrr/Desktop/dwe_devep/r.in.globcover.py'
if [ ! -d /usr/local/grass-6.4.0svn/scripts ]; then mkdir -p /usr/local/grass-6.4.0svn/scripts; fi
/usr/bin/install -c r.in.globcover.py /usr/local/grass-6.4.0svn/scripts/r.in.globcover.py
make htmlscript scriptstrings
make[1]: Entering directory `/home/anrr/Desktop/dwe_devep/r.in.globcover.py'
make /usr/local/grass-6.4.0svn/docs/html/r.in.globcover.py.html HTMLSRC=/usr/local/grass-6.4.0svn/scripts/r.in.globcover.py
make[2]: Entering directory `/home/anrr/Desktop/dwe_devep/r.in.globcover.py'
if [ "/usr/local/grass-6.4.0svn/scripts/r.in.globcover.py" != "" ] ; then GISRC=/usr/local/grass-6.4.0svn/demolocation/grassrc64 GISBASE=/usr/local/grass-6.4.0svn PATH="/usr/local/grass-6.4.0svn/bin:$PATH" LD_LIBRARY_PATH="/usr/local/grass-6.4.0svn/bin:/usr/local/grass-6.4.0svn/lib:" LC_ALL=C /usr/local/grass-6.4.0svn/scripts/r.in.globcover.py --html-description < /dev/null | grep -v '</body>\|</html>' > r.in.globcover.py.tmp.html ; true ; fi
  File "/usr/local/grass-6.4.0svn/scripts/r.in.globcover.py", line 50, in <module>
    import grass.script as grass
*ImportError: No module named grass.script*
I thought GRASS6.4 Python's script already had this module. Is not available?
Just one last question: How can I retrieve image projection, using a Python script, with tghe same information-structure I get when I use: grass.read_command('g.proj', flags = 'jf').strip()
Thanks
Best regards,
Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5215 (20100621) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
in <module>
available?
6.4 has the Python modules, but the build system doesn't support
Python scripts (it doesn't set PYTHONPATH when executing commands).
You will need to modify the definition of htmldesc in
include/Make/Html.make to set PYTHONPATH to include
$(GISBASE)/etc/python (making it work on Windows isn't
straightforward, so I don't expect it to change in 6.x).
grass.read_command('g.proj', flags = 'jf', georef = filename).strip()
What does this means? That I won't be able to run Python Scripts in 6.4?
This means that now htmldesc becomes this?
htmldesc = \
   GISRC=$(RUN_GISRC) \
   GISBASE=$(RUN_GISBASE) \
   PATH="$(BIN):$$PATH" \
       PYTHONPATH= "$(GISBASE)/etc/python" \
   $(LD_LIBRARY_PATH_VAR)="$(BIN):$(ARCH_LIBDIR):$($(LD_LIBRARY_PATH_VAR))" \
   LC_ALL=C $(1) --html-description < /dev/null | grep -v '</body>\|</html>' > $(PGM).tmp.html ; true
> My first test seems to be fully working. Thanks :slight_smile:
THanks
Best regards,
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5216 (20100621) __________
http://www.eset.com
You can run a Python script once you've managed to install it, but you
can't just drop it into the source tree, as the 6.x build system
doesn't support Python scripts.
htmldesc = \
Other than the formatting, that looks about right for Unix, provided
that PYTHONPATH was empty to start with. For Windows, you need to
convert the path to Windows' syntax.
2010/6/23 Glynn Clements <glynn@gclements.plus.com>:
what is missing - any pointers?
The handling of scripts is entirely different between 6.x and 7.0.
In 6.x, a script is "made" by installing a file of the same name from
the current directory to the scripts directory. On Windows, a
corresponding .bat file is also generated.
In 7.0, the target script has a .py extension on Windows but not on
other platforms. The source script always has a .py suffix. Shell
scripts aren't supported.
If you want to include Python scripts in 6.x, the Makefile would need
to provide the necessary rules; there isn't anything in *.make (in
either 6.x or 7.0) which will help.
On Wed, Jul 28, 2010 at 5:35 AM, Glynn Clements
I suspect that it would be a clone of
include/Make/Script.make
adapted to Python with a new target
default: python
default: python
You would need separate *.make files for shell and Python scripts, and
any given Makefile could only include one of them (otherwise they'll
provide conflicting rules to generate the target).
