[GRASS-dev] grass6 and python array
Hi All,
do you know if the nice ability to import grass maps
directly in a numpy array (as already in grass7)
will be backported to grass6 too ?
thanks!
Massimo.
The grass.script.array module in GRASS 7 relies upon some changes
which were made to r.in.bin and r.out.bin, so it can't be used as-is.
It could be modified to work with the 6.x versions, although it would
require some changes. The main issues with the 6.x versions are:
1. You can't choose the output format (other than forcing integer
output with -i). The output is in the same format as the map, so you
would need to use "r.info -t ..." to determine the format of the data.
2. Integers are truncated to 16 bits.
Hi Glynn,
thanks for your help!
i'll try an other way to store map data into an array,
i can use directly python-gdal, but i'll try to find a grass way to do the same
