[GRASS-dev] grass6_devel, problems to find gdal library
Hi
i'm tring to update grass from svn, on osx .
the configure find gdal-config
but fail to find gdal libraries
checking for location of JPEG includes... /Library/Frameworks/UnixImageIO.framework/unix/include
checking for jpeglib.h... yes
checking for location of JPEG library... /Library/Frameworks/UnixImageIO.framework/unix/lib
checking for jpeg_start_compress in -ljpeg... yes
checking whether to use GDAL... yes
checking for gdal-config... /Library/Frameworks/GDAL.framework/Programs/gdal-config
configure: error: *** Unable to locate GDAL library.
using the same configure (and the same gdal libraries)
on the svn code downloaded 2 weeks ago
(i don't know how to check the exact release it is),
it works as aspected
thanks for any suggestion,
regards
Massimo Di Stefano.
Chiacchiera con i tuoi amici in tempo reale! http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
same error on Debian/Sid for a couple of days now.
2008/7/4 Massimo Di Stefano <massimodisasha@yahoo.it>:
Hi
regards
Massimo Di Stefano.
reale!http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
grass-dev mailing list
grass-dev@lists.osgeo.org
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
Look in config.log for the command which fails and any error messages
which it generates.
config.log
configure:7599: checking whether to use GDAL
configure:7612: checking for gdal-config
configure:7677: gcc -o conftest -g -O2 -Wl,--export-dynamic
conftest.c -L/usr/lib -lgdal1.5.0 1>&5
configure:7671:18: error: gdal.h: No such file or directory
configure: In function 'main':
configure:7673: error: 'GA_ReadOnly' undeclared (first use in this function)
configure:7673: error: (Each undeclared identifier is reported only once
configure:7673: error: for each function it appears in.)
configure: failed program was:
#line 7670 "configure"
#include "confdefs.h"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
configure:7693: gcc -o conftest -g -O2 -Wl,--export-dynamic
conftest.c -L/usr/lib -lgdal1.5.0 -L/usr/lib -lgeos_c -I/usr/include
-lsqlite3 -lodbc -lodbcinst -L/usr/lib -lexpat -L/usr/lib -lxerces-c
-lpthread -ljasper -lhdf5 -lmfhdf -ldf -logdi -lgif -ljpeg -ltiff
-lpng -lnetcdf -lpq -L/usr/lib -lpq -lz -lpthread -lm -lrt -ldl -lcurl
-L/usr/lib/mysql -lmysqlclient 1>&5
configure:7687:18: error: gdal.h: No such file or directory
configure:7689: error: 'GA_ReadOnly' undeclared (first use in this function)
configure:7689: error: (Each undeclared identifier is reported only once
configure:7689: error: for each function it appears in.)
#line 7686 "configure"
#include <gdal.h>
int main() {
; return 0; }
locate gdal.h returns: /usr/include/gdal/gdal.h
Added in configure options:
--with-includes=/usr/include/gdal
and it compiled properly
Thanks Glynn
Yann
2008/7/5 Glynn Clements <glynn@gclements.plus.com>:
which it generates.
Yann Chemin
Finally had a chance to try it myself. Looks like changes in r31909 broke it. The tests are now including gdal.h, yet the GDAL include path isn't added to the test compile:
configure:7677: gcc -o conftest -Os -arch ppc -arch i386 -arch ppc -arch i386 -arch ppc -arch i386 conftest.c -L/Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib -lgdal 1>&5
which it generates.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
On Sun, Jul 6, 2008 at 7:29 PM, William Kyngesburye
That r31909 change is the backport of
http://trac.osgeo.org/grass/changeset/31861
Timestamp: 06/27/08 12:48:11 (1 week ago)
Author: glynn
Message:
    Add LOC_CHECK_LINK to allow checking Windows (stdcall) libraries
    Change GDAL ODBC checks to handle stdcall
[yes, I'll start to add the change rev into the backports]
It was also broken on grass.osgeo.org (Fedora, builds snapshots
and prog-man), Yann's include trick is a work-around.
Author: glynn
Message:
Fixed in trunk in r32030.
On Sun, Jul 6, 2008 at 8:33 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
Backported to 6.4.svn in r32031.
Works for me now on OSX.
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
