Helena,
I have no trouble compiling GRASS 6.5. I'm using current (or recent as of June) frameworks from William's site. I'm running OS X 10.6. My wxPython installed for Python 2.5 instead of 2.6, but it should work with 2.6 too. I would just need to change the --with-wxwidgets argument. Here is my config line:
cmb-MBP:grass70_dev cmbarton$ ./configure --with-freetype --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --with-cxx --with-opengl=aqua --without-readline --prefix=/Applications/GRASS --enable-macosx-app --with-python=/System/Library/Frameworks/Python.framework/Versions/2.5/bin/python2.5-config --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.10.1/bin/wx-config --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /Library/Frameworks/Tk.framework/PrivateHeaders" --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386 x86_64"
Following William's suggestion, I've also dealt with aqua TclTk issues (for NVIZ) using the following setup:
Create folder...
/usr/local/tcltk_active/lib/...
make links to the ActiveTcl framework binaries
libtcl.dylib -> /Library/Frameworks/Tcl.framework/Versions/8.5/Tcl
libtcl8.5.dylib -> /Library/Frameworks/Tcl.framework/Versions/8.5/Tcl
libtclstub8.5.a -> /Library/Frameworks/Tcl.framework/Versions/8.5/libtclstub8.5.a
libtk.dylib -> /Library/Frameworks/Tk.framework/Versions/8.5/Tk
libtk8.5.dylib -> /Library/Frameworks/Tk.framework/Versions/8.5/Tk
libtkstub8.5.a -> /Library/Frameworks/Tk.framework/Versions/8.5/libtkstub8.5.a
Then configure grass with:
Tk.framework/PrivateHeaders" --with-tcltk-libs=/usr/local/tcltk_active/
lib
I hope this helps.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 7, 2010, at 9:00 AM, <grass-dev-request@lists.osgeo.org> <grass-dev-request@lists.osgeo.org> wrote:
Date: Sat, 7 Aug 2010 11:50:38 -0400
Subject: Re: [GRASS-dev] grass65 compilation on mac OSX
To: William Kyngesburye <kyngchaos@kyngchaos.com>
Cc: "grass-dev@lists.osgeo.org list" <grass-dev@lists.osgeo.org>
Message-ID: <53E741A9-E14A-4636-AC32-5F02399D3F44@unity.ncsu.edu>
Content-Type: text/plain; charset=us-asciiWilliam,
thanks for the hint for compilation of grass7, it worked. Now I am trying to compile from source also 6.5 and
everything runs except the old nviz - I am getting similar error:Undefined symbols for architecture x86_64:
"_GetPortBounds", referenced from:
_SetMacBufRect in togl.o
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
lipo: can't open input file: /var/folders/-w/-wN910nTFamsDLR+fBkvB++++TI/-Tmp-//cc1B1KT1.out (No such file or directory)
make[1]: *** [/Users/helena/grassdev6/develbranch_6/dist.i386-apple-darwin10.2.0/bin/nviz] Error 1
make: *** [default] Error 2Below is my config file, I am wondering what am I missing this time.
BTW, I have nviz running on this machine in grass64 using your binary.thanks a lot for any hints,
