[GRASS-dev] grass65 installation error
c1plus: warning: command line option “-Wstrict-prototypes” is valid for Ada/C/ObjC but not for C++
In file included from /usr/include/python2.6/Python.h:8,
from nviz.h:28,
from change_view.cpp:15:
/usr/include/python2.6/pyconfig.h:1031:1: warning: “_POSIX_C_SOURCE” redefined
In file included from /usr/include/assert.h:37,
from /usr/include/wx-2.8/wx/debug.h:18,
from /usr/include/wx-2.8/wx/defs.h:521,
from /usr/include/wx-2.8/wx/wxprec.h:13,
from nviz.h:5,
/usr/include/features.h:158:1: warning: this is the location of the previous definition
from nviz.h:28,
/usr/include/python2.6/pyconfig.h:1040:1: warning: “_XOPEN_SOURCE” redefined
from nviz.h:5,
/usr/include/features.h:160:1: warning: this is the location of the previous definition
change_view.cpp: In member function ‘std::vector<double, std::allocator > Nviz::SetViewDefault()’:
change_view.cpp:56: error: cannot convert ‘float*’ to ‘double*’ for argument ‘1’ to ‘int Nviz_get_exag_height(double*, double*, double*)’
change_view.cpp: In member function ‘int Nviz::SetView(float, float, float, float, float)’:
change_view.cpp:81: error: cannot convert ‘nv_data*’ to ‘double’ for argument ‘1’ to ‘int Nviz_set_viewpoint_height(double)’
change_view.cpp:83: error: cannot convert ‘nv_data*’ to ‘double’ for argument ‘1’ to ‘int Nviz_set_viewpoint_position(double, double)’
change_view.cpp:85: error: invalid conversion from ‘nv_data*’ to ‘int’
/home/rashad/grass6_devel/dist.i686-pc-linux-gnu/include/grass/nviz.h:134: error: too many arguments to function ‘int Nviz_set_viewpoint_twist(int)’
change_view.cpp:85: error: at this point in file
change_view.cpp:87: error: invalid conversion from ‘nv_data*’ to ‘int’
/home/rashad/grass6_devel/dist.i686-pc-linux-gnu/include/grass/nviz.h:133: error: too many arguments to function ‘int Nviz_set_viewpoint_persp(int)’
change_view.cpp:87: error: at this point in file
error: command ‘gcc’ failed with exit status 1
make: *** [OBJ.i686-pc-linux-gnu/_grass6_wxnviz.so] Error 1
Rashad
2010/7/6 Mohammed Rashad <rashadkm@yahoo.com>:
error: command 'gcc' failed with exit status 1
wxNviz waits for ctypes backport. Please ignore these errors for a while.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
