I created a new user (also administrator) on a MacBook and started to follow Michael’s steps to install version 7 Maverick
I get a strange error on install, the directory GRASS (inside is the application grass-7.0) is there but I do not have permission to open the directory in Finder (though I did install it). Going to the “main” user of the machine I could change the permissions, and also checked that GRASS7.0 runs well, all good there, no worries.
Going back to my user, I can go in the directory, and launch the application, ok. Then things go weird. It was working well in the “main” user but bugs in that new user… Both have admin level.
Python 2.7.5 found.
WELCOME TO GRASS 7.0.svn
Have at your side all available GRASS GIS tutorials
When working on your location, the following materials
are extremely useful:
A topographic map of your area
Current catalog of available computer maps
- heck the GRASS GIS web pages for supporting mailing lists and more:
Hit RETURN to continue
Starting GRASS GIS…
File “/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gis_set.py”, line 37, in
from core.utils import _
File “/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/utils.py”, line 36, in
from core.gcmd import RunCommand
File “/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/gcmd.py”, line 744, in
_enc = GetDefaultEncoding() # define as global variable
File “/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/core/gcmd.py”, line 737, in GetDefaultEncoding
enc = locale.getdefaultlocale()[1]
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py”, line 511, in getdefaultlocale
return _parse_localename(localename)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py”, line 443, in _parse_localename
raise ValueError, ‘unknown locale: %s’ % localename
ValueError: unknown locale: UTF-8
Error in GUI startup. If necessary, please report this error to the GRASS developers.
Switching to text mode now.
