Nikos Alexandris:
A fresh, (make dist)clean(ed) and error-free configured & compiled
grass7_trunk under Funtoo (3.12.18-KS.01) won't launch:
# /osgeo/grass70_release/bin.x86_64-unknown-linux-gnu $ ./grass70
Markus Neteler:
Do you use trunk or release branch?
/usr/bin/python2.7: can't open file
'/osgeo/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/gui/wxpython/gis_set.py':
[Errno 2] No such file or directory
Received EXIT message from GUI.
# /osgeo/grass70_release/bin.x86_64-unknown-linux-gnu $ ./grass70 -text
To me it looks like you have a mixed version of trunk and relbr70...
I have downloaded both and tested both separately. The configuration and compilation is done in the respective source directories separately, i.e.: grass70_release and grass7_trunk as downloaded per svn. Trying to be as clean as possible, I wiped out grass7_trunk and kept only grass70 on-disk. I make a simple configuration
# in grass70_release directory
make distclean
./configure --with-freetype-includes="/usr/include/freetype2/"
GRASS is now configured for: x86_64-unknown-linux-gnu
Source directory: /osgeo/grass70_release
Build directory: /osgeo/grass70_release
Installation directory: ${prefix}/grass-7.0.0svn
Startup script in directory:${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
OpenGL platform: X11
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
BLAS support: no
C++ support: yes
Cairo support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: no
LAPACK support: no
Large File support (LFS): yes
libLAS support: no
MySQL support: no
NetCDF support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenCL support: no
OpenGL support: yes
OpenMP support: no
PNG support: yes
POSIX thread support: no
PostgreSQL support: no
Readline support: no
Regex support: yes
SQLite support: no
TIFF support: yes
wxWidgets support: no
X11 support: yes
# compile
make -j5
Started compilation: Thu May 8 11:50:16 EEST 2014
Errors in:
No errors detected.
Finished compilation: Thu May 8 11:54:11 EEST 2014
# launch grass
/osgeo/grass70_release/bin.x86_64-unknown-linux-gnu $ ./grass70 /geo/grassdb/wgs84/PERMANENT/
WELCOME TO GRASS 7.0.0svn
1) Have at your side all available GRASS GIS tutorials
2) When working on your location, the following materials
are extremely useful:
- A topographic map of your area
- Current catalog of available computer maps
3) Check the GRASS GIS web pages for supporting mailing lists and more:
http://grass.osgeo.org
Hit RETURN to continue
Starting GRASS GIS...
File "./grass70", line 1386, in <module>
check_lock()
File "./grass70", line 857, in check_lock
ret = call([gfile("etc", "lock"), lockfile, "%d" % os.getpid()])
File "./grass70", line 154, in call
return subprocess.call(cmd, **kwargs)
File "/usr/lib64/python2.7/subprocess.py", line 522, in call
return Popen(*popenargs, **kwargs).wait()
File "/usr/lib64/python2.7/subprocess.py", line 709, in __init__
errread, errwrite)
File "/usr/lib64/python2.7/subprocess.py", line 1326, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
Same error again. I must have something wrong with my local configuration (all this in a new machine). In my other Funtoo-box, I don't remember having done something differently. For example, I didn't need to setup anything in ld.so.conf.
