[GRASS-dev] grass7 ccmath, gmath and gpde libraries svn update
Hello,
i have added the ccmath library to grass7 trunk, the patched/enhanced versions
of the gmath and gpde libraries and updated versions of r/r3.gwflow,
i.cca, i.pca and i.smap.
Its a port from grass6.5.
It is a major update and I have tested it several times, but only on a
suse linux 11.1 system.
So hopefully i did not break anything. :slight_smile:
Any feedback is welcome.
Best regards
Soeren
2009/10/3 Soeren Gebbert <soerengebbert@googlemail.com>:
Thanks!
Just cosmetics, missing EXTRA_LIBS in Makefile (fixed).
I am just thinking why it came first to devbr6 and not trunk;-)
Probably we should focus on trunk and GRASS 7...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Hi Martin,
2009/10/3 Martin Landa <landa.martin@gmail.com>:
Thanks!
Thanks, i guess i need to update the gmath Makefile for the same reason too.
I was working on this patch since 2007. IIRC grass7 was not
established at this time.
So patching grass6.5 was the first target on my mind. :slight_smile:
Additionally it was important for me to remove the numerical recipes
code from grass6 too,
which will be IMHO for the next years the standard version for many users.
And i am still not finished, gmath/lu.c must be replaced too and many
modules must be patched to use
the new gmath solver and the blas functions ... .
Soeren
Martin
Great, I am looking forward...
Martin
