Dear All,
I'm trying to make a virtual machine with GRASS7 on Fedora 22 (only
grass64 is available so far), I didn't have any particular problem
configuring with:
./configure \
--with-cxx \
--with-gdal=/usr/bin/gdal-config \
--with-proj --with-proj-share=/usr/share/proj \
--with-sqlite \
--with-nls \
--with-wxwidgets=/usr/bin/wx-config \
--with-fftw \
--with-python=/usr/bin/python-config \
--with-freetype --with-freetype-includes=/usr/include/freetype2 \
--enable-largefile \
--without-odbc
and then compiling...
but when I start GRASS I got this Error:
$ grass71
Fatal Error: Mismatch between the program and library build versions detected.
The library used 3.0 (wchar_t,compiler with C++ ABI 1008,wx
containers,compatible with 2.8),
and wxPython used 3.0 (wchar_t,compiler with C++ ABI 1002,wx
containers,compatible with 2.8).
ERROR: Invalid return code from GUI startup script.
Please advise GRASS developers of this error.
Exiting...
Any ideas?
Pietro
On Mon, May 4, 2015 at 10:55 PM, Pietro <peter.zamb@gmail.com> wrote:
Dear All,
$ grass71
Exiting...
I just tried the same using docker (for the procedure, see the comment here:
http://courses.neteler.org/fun-docker-grass-gis-software/#comment-1168 )
Essentially I get the same error.
Any ideas?
On Mon, May 4, 2015 at 4:55 PM, Pietro <peter.zamb@gmail.com> wrote:
Dear All,
configuring with:
./configure \
--with-cxx \
--with-sqlite \
--with-nls \
--with-fftw \
--without-odbc
$ grass71
detected.
Exiting...
Any ideas?
Nothing in particular, but you can try to `import wx` in Python command
line inside and outside of GRASS session to see what happens.
Vaclav
Pietro
grass-dev mailing list
grass-dev@lists.osgeo.org
On Mon, May 4, 2015 at 11:04 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Nothing in particular, but you can try to `import wx` in Python command line
ok, I've tried with:
$ python -c "import wx"
Cancelled (core dump created)
Therefore it seems not a GRASS problem... but more a library/distribution one.
Do you know where this problem should be point out?
Pietro
I guess in Fedora's bugtracker, e.g. referring to this ticket (just found it):
https://bugzilla.redhat.com/show_bug.cgi?id=1217955
