[GRASS-dev] GRASS7 ImageryLib
All,
I found these here[1] and says many things which needed help. So I thought to give a try in order
  1. Imagery Library needs fundamental clean up (the library is not maintained from GRASS 5)
Anyone can elaborate on this line?
  1. Reimplement groups to be generic element (in GIS Library)
I guess i.group module should be g.group which can groups both raster/vector maps
Is that correct?
please reply back with some comments/suggestion regarding these two
[1] http://trac.osgeo.org/grass/wiki/Grass7/ImageryLib
Rashad
On Fri, Nov 30, 2012 at 5:26 AM, Mohammed Rashad
<mohammedrashadkm@gmail.com> wrote:
All,
from GRASS 5)
Fully agreed.
It might be sensible to merge the various image libraries:
GRASS 6/7:
* lib/imagery/: standard lib, in use (i.* except for i.points3,
i.rectify3, see below)
* imagery/i.ortho.photo/libes/: standard lib, in use (i.ortho.photo, photo.*)
GRASS 5 (! only) image3 lib:
* libes/image3/: never finished improvement which integrated the
standard lib and the ortho lib. Seems to provide also ortho
rectification for satellite data (i.points3, i.rectify3)
GRASS 5/6 image proc commands:
* merge of i.points, i.vpoints, i.points3 (see above)
* merge of i.rectify and i.rectify3 (see above)
Overall
* add other warping methods (maybe lanczos or thin splines from GDAL?)
However, the library cleanup in GRASS 7 would be essential.
2. Reimplement groups to be generic element (in GIS Library)
maps
Is that correct?
Correct I don't know, maybe subject to discussion.
Best
> All,
thought
maintained
> from GRASS 5)
Fully agreed.
GRASS 6/7:
photo.*)
i.points3 and i.rectify3 doesnt uses standard lib. So adding API style code
which can be used by i.point3 and i.rectify3 is what you are saying. Am I
correct?
i.ortho.photo uses i.ortho.photo/libes right?
so merging both libs will provide an API which any grass imagery module can
share right?
Overall
This part is not clear to me at all
raster/vector
> maps
> Is that correct?
Anyone have any comments ?
Best
   Rashad
[answering here because I have worked on some of the affected modules]
On Wed, Dec 5, 2012 at 6:16 PM, Mohammed Rashad
> All,
> thought
> maintained
> from GRASS 5)
Fully agreed.
GRASS 6/7:
photo.*)
correct?
I guess so, but I would suggest to move the libs needed by i.points3
and i.rectify3 to a separate GRASS lib, probably ortholib
No, it uses (will use) ortholib, currently i.ortho.photo/lib, but I am
busy porting it and related modules to trunk.
share right?
I would suggest to separate standard imagery lib and
orthorectification, because these two use substantially different
algorithms. The ortholib depends on imager lib.
Overall
Lanczos is already available.
What could be gained by adding thin splines to the existing bilinear,
bicubic, bspline, lanczos methods?
Markus M
> raster/vector
> maps
> Is that correct?
Best
   Rashad
grass-dev mailing list
grass-dev@lists.osgeo.org
On Sun, Dec 9, 2012 at 1:51 AM, Markus Metz
>> > All,
>> > thought
>> > maintained
>> > from GRASS 5)
>> Fully agreed.
>> GRASS 6/7:
>> photo.*)
code
> correct?
can
> share right?
i.ortho.photo is under progress right? . So moving imager to a lib called
ortholib under imagery like imagery/ortholib or as grass_trunk/ortholib is
need to be done. right?
So If I start moving code around will it affect the current work on i.ortho
and friends?
>> Overall
This question is not clear for me
Markus M
>> > raster/vector
>> > maps
>> > Is that correct?
>> Best
>> Markus
> Regards,
> Rashad
   Rashad
On Sun, Dec 9, 2012 at 5:30 AM, Mohammed Rashad
On Sun, Dec 9, 2012 at 1:51 AM, Markus Metz <markus.metz.giswork@gmail.com>
>> > All,
>> > thought
>> > maintained
>> > from GRASS 5)
>> Fully agreed.
>> GRASS 6/7:
>> photo.*)
> code
> I
> correct?
> can
> share right?
I would prefer lib/ortho.
and friends?
Yes. I have already modified imagery/i.ortho.photo/lib in trunk but
not yet submitted. It's working now for me in trunk, as well as
i.photo.rectify. Please don't modify imagery/i.ortho.photo/lib before
I have submitted my changes.
>> Overall
These interpolation methods are used by i.rectify, i.photo.rectify,
r.proj, r.resamp.interp. Adding thin splines might be a valuable
addition, but it could also cause confusion (too many methods to
choose from). These methods are in lib/raster/interp.c.
Markus M
>> > raster/vector
>> > maps
>> > Is that correct?
>> Best
>> Markus
> Regards,
> Rashad
   Rashad
