[GRASS-dev] grass7 memory corruption again
I am facing to the crazy memory corruption again, e.g. now v.db.select
segfaults. It's always related to Vect_open_old-*() fns. On line 118
in main.c is called Vect_open_old_head(). Before the function call
(gdb) p fs_opt->answer
$13 = 0xb7f0aea9 "|"
OK
after
$14 = 0x0
... I reported this kind of problem several times in the past. It's
seems there is nobody who is facing to the similar problem or am I
wrong?
Martin
Debian GNU/Linux Sid
gcc (Debian 4.3.3-10) 4.3.3
        CFLAGS="-g -Wall -Werror-implicit-function-declaration
-fno-common -Wextra -Wunused" \
      CXXFLAGS="-g -Wall" \
      ./configure --prefix=/usr/local \
      --with-tcltk-includes=/usr/include/tcl8.4
--with-tcltk-libs=/usr/lib/tcl8.4 \
      --with-postgres --with-postgres-includes=/usr/include/postgresql \
      --with-mysql --with-mysql-includes=/usr/include/mysql \
      --with-gdal=/usr/local/gdal-grass7/bin/gdal-config \
      --with-proj \
      --with-motif --with-glw --with-nls --with-readline \
      --with-cxx --enable-largefile \
      --with-freetype --with-freetype-includes=/usr/include/freetype2 \
      --with-sqlite --with-ffmpeg --with-ffmpeg-includes=/usr/include/ffmpeg/ \
      --with-odbc --with-python=/usr/bin/python2.5-config
--with-wxwidgets --with-pthread \
      --with-ffmpeg=no --with-geos=/usr/local/bin/geos-config
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
