[GRASS-dev] grass7: problem --with-liblas
I have compiled liblas from the repo [1] and then grass7 with
`--with-liblas`, unfortunately without success
configure:6544: checking for liblas-config
configure:6599: gcc -o conftest -g -Wall
-Werror-implicit-function-declaration -fno-common -Wextra -Wunused
-Wl,--export-dynamic conftest.c -L/usr/local/lib -llas -llas_c
-L/usr/lib optimized;/usr/lib/libboost_program_options-mt.so;debug;/usr/lib/libboost_program_options-mt.so
1>&5
gcc: error: optimized;/usr/lib/libboost_program_options-mt.so;debug;/usr/lib/libboost_program_options-mt.so:
No such file or directory
configure: failed program was:
#line 6592 "configure"
#include "confdefs.h"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
having
$ gcc --version
gcc (Debian 4.6.0-10) 4.6.1 20110526 (prerelease)
$ liblas-config --libs
-L/usr/local/lib -llas -llas_c -L/usr/lib
Any hint? Martin
[1] http://liblas.org/compilation.html#using-unix-makefiles-on-linux
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Tue, May 31, 2011 at 10:00 AM, Martin Landa <landa.martin@gmail.com> wrote:
1>&5
int main() {
; return 0; }
having
$ gcc --version
Any hint? Martin
I am not sure if this second line returned by liblas-config --libs
starting with "optimized;" is valid. On my installation, liblas-config
--libs gives me
-L/usr/local/lib -llas -llas_c -L/usr/lib64
/usr/lib64/libboost_program_options-mt.so /usr/local/lib64/libgdal.so
/usr/local/lib64/libgeotiff.so /usr/lib64/libtiff.so
/usr/lib64/libxml2.so /usr/local/lib64/liblaszip.so
Is lasinfo working at all? Just a wild guess: have you changed the
default CMAKE_BUILD_TYPE? And just out of curiosity: can you send me
(offlist) your liblas-config file?
Markus M
FWIW, I have exactly the same problem.
It isn't.
--libs gives me
The relevant line from liblas-config is:
LIBS="-L$libdir -llas -llas_c -L/usr/lib optimized;/usr/lib/libboost_program_options-mt-1_42.so;debug;/usr/lib/libboost_program_options-mt.so"
On Tue, May 31, 2011 at 6:03 PM, Glynn Clements
It isn't.
--libs gives me
here:
LIBS="-L$libdir -llas -llas_c -L/usr/lib64
/usr/lib64/libboost_program_options-mt.so"
Is this "optimized;" and ";debug;" now a problem of GRASS or of libLAS?
Anyway, as a local fix, configure could be hacked, replacing line 6582
    LIBLAS_LIBS=`"$LIBLAS_CONFIG" --libs`
with
    LIBLAS_LIBS="-L/usr/local/lib -llas -llas_c"
-L/usr/local/lib may need to b replaced with the actual location of liblas_c.so
BTW, what version of libLAS are you using?
Markus M
2011/5/31 Markus Metz <markus.metz.giswork@googlemail.com>:
source from the repo
http://liblas.org/development/source.html#source
Martin
yes
no
Martin
On Tue, May 31, 2011 at 6:22 PM, Martin Landa <landa.martin@gmail.com> wrote:
try the current stable release 1.6.1 instead
http://liblas.org/download.html
Markus M
getting the same
on Debian GNU/Linux Sid
Martin
libLAS. Although it / be an issue with CMake's FindBoost module
(search for "optimized" in FindBoost.cmake).
I'm using the libLAS-1.6.1 source package:
  $ ls -l libLAS-*
  -rw-r--r-- 1 glynn root 7817956 May 30 18:49 libLAS-1.6.1.tar.gz
  $ md5sum libLAS-*
  2ce4f36f267c2f25bfc99c3f00e9cbd3 libLAS-1.6.1.tar.gz
On Tue, May 31, 2011 at 11:34 PM, Glynn Clements
This seems to be a bug in cmake 2.8.4, not present in cmake 2.8.2. I
just updated cmake from 2.8.2 to 2.8.4 and now get the same problem.
Or the syntax in liblas-config.in is wrong.
I suggest to hack liblas-config and replace the offending line
with
or
   $ ls \-l libLAS\-\*
   \-rw\-r\-\-r\-\- 1 glynn root 7817956 May 30 18:49 libLAS\-1\.6\.1\.tar\.gz
   $ md5sum libLAS\-\*
   2ce4f36f267c2f25bfc99c3f00e9cbd3  libLAS\-1\.6\.1\.tar\.gz
2011/6/1 Markus Metz <markus.metz.giswork@googlemail.com>:
should be probably reported in libLAS ML...
Martin
Hi Folks,
Glynn’s suggested hack to liblas-config below to work around the issue in cmake allowed me to compile grass7 with liblas support over the weekend on Ubuntu 11.04 x64. I have not read any las files yet to see if it actaully worked :slight_smile: , hopefully tonight I’ll get a chance.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
Sent by: grass-dev-bounces@lists.osgeo.org
06/01/2011 03:21 AM
To
cc
Martin Landa <landa.martin@gmail.com>, GRASS developers list <liblas-devel@lists.osgeo.org>
Subject
Re: [GRASS-dev] grass7: problem --with-liblas
with
or
> $ ls -l libLAS-*
> $ md5sum libLAS-*
grass-dev mailing list
grass-dev@lists.osgeo.org
