Martin Landa:
> I would suggest to rename DB related G_OPTs in parser.c to
> G_OPT_DB_, e.g. G_OPT_WHERE to G_OPT_DB_WHERE.
> Since those defines were added recently, maybe could be possible to
> rename them also in grass6 (or to define aliases) ?
no aliases cluttering things up please, lets just do the job right, once.
AFAIK we only guarantee the user interface is stable within grass 6.x, not the library interface.
On Sun, Aug 10, 2008 at 3:16 PM, Hamish <hamish_b@yahoo.com> wrote:
Martin Landa:
+1
Are these G_OPTs externally used (GDAL, SWIG..)?
If not, let's do it also in (devbr6).
> once. AFAIK we only guarantee the user interface is stable
Markus:
(R interface, QGIS, ...)
Well I doubt they are used much. Especially as these are DB options.
upon reflection, one thing to consider is- are these used by addon C modules?
Looking through the addons svn I see 190 G_OPT_*, but those are limited to
G_OPT_R_INPUT
G_OPT_R_INPUTS
G_OPT_R_OUTPUT
G_OPT_V_FIELD
G_OPT_V_INPUT
G_OPT_V_OUTPUT
G_OPT_V_TYPE
+1
You might also consider back-porting r31628, which checks that the
module was built with the same version of gis.h as libgis.
