On 3/20/13, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Patch that removes the buggy LRE compression has been applied to trunk
#55462. Tests for 3D raster modules and the library passed
successfully. The patch should assure backward compatibility.
I hope i did not break anything.
The backward compatibility may be tested with
http://grass.osgeo.org/download/sample-data/
-> Slovakia precipitation data
Slovakia 3D precipitation voxel data set
BTW: Can anyone else donate a second voxel data set? I have only
my own head which I reconstructed from a recent CT scan but the data
license is unclear
