On Wed, Sep 4, 2013 at 3:41 PM, Rashad M <rashadkm@gmail.com> wrote:
gis_set.py was included in grass-gui package. I had seen this issue earlier with someone and still didnt fixed it yet. Sorry its a fault on my side if its not fixed by adding grass-gui package. If so I will find some tim this sunday to fix the problem
Has this issue already been solved? Today, after some time I uninstalled and reinstalled grass70 (and grass-gui) from the ubuntugis-ppa to check if it working now. But still I can’t launch the GUI with a slightly different error now. I seems that it is now pointing a least to GRASS70:
Hit RETURN to continue
Starting GRASS GIS…
python: can’t open file ‘/usr/lib/grass70/etc/gui/wxpython/gis_set.py’: [Errno 2] No such file or directory
Received EXIT message from GUI.
I checked an I also couldn’t find the folder gui under /usr/lib/grass70/etc/
/Johannes
On Wed, Sep 4, 2013 at 3:25 PM, Johannes Radinger <johannesradinger@gmail.com> wrote:
No problem…as I said I just rolled back to precise. So no worry about raring for the moment. On precise I am able to install grass70 from grass-devel ppa and grass643 from ubuntugis-unstable…
However when I try to launch both from the console (freshly installed precise) via grass64 or grass70 I get an error:
python: can’t open file ‘/usr/lib/grass64/etc/wxpython/gis_set.py’: [Errno 2] No such file or directory
resp.
python: can’t open file ‘/usr/lib/grass70/etc/wxpython/gis_set.py’: [Errno 2] No such file or directory
Any idea about that?
/Johannes
Rashad
On Wed, Sep 4, 2013 at 2:28 PM, Rashad M <rashadkm@gmail.com> wrote:
there was some problem on raring and I couldn’t get time to work on it. Anyway I will add it to my calender again and let see if I can figure it out. The main problem is I dont have a raring currently I need to login to a remote system at my university and do it. I will try this weekend and let you know
On Wed, Sep 4, 2013 at 2:25 PM, Johannes Radinger <johannesradinger@gmail.com> wrote:
At the moment I also saw that the last build failed for raring…
so for the moment I’ll reinstall precise to test grass70
Rashad
On Wed, Sep 4, 2013 at 2:18 PM, Rashad M <rashadkm@gmail.com> wrote:
the recipe was not building for raring but I enabled it and you can check back in a while
On Wed, Sep 4, 2013 at 1:42 PM, Johannes Radinger <johannesradinger@gmail.com> wrote:
that one is installed…thats why I am wondering.
I am running Xubuntu (latest actually todays version). The repo
is also listed (e.g. in Synaptic and I see the grass-add ons but
not the grass70)
Maybe because of my new Xubuntu version (Raring ringtail)?
Rashad
On Wed, Sep 4, 2013 at 1:29 PM, Rashad M <rashadkm@gmail.com> wrote:
sudo add-apt-repository ppa:grass/grass-devel
you may need to install add-apt-repository using apt-get install
On Wed, Sep 4, 2013 at 12:15 PM, Johannes Radinger <johannesradinger@gmail.com> wrote:
Hi Rashad,
I just need your little help:
I added the grass-devel PPA to my repository and ran sudo apt-get update
however there is no grass70 listed which I can install via apt-get install gra*
There is a grass and grass-devel listed which seems to be related to the grass 6.4.2
(is in the official ubuntu repo?)
Rashad
On Wed, Sep 4, 2013 at 11:51 AM, Rashad M <rashadkm@gmail.com> wrote:
Yes you are right. grass64 is uploaded in UbuntuGIS-unstable PPA when there is new release including RC’s. GRASS PPA has daily builds for grass64, grass70 and grass-addons. I am sorry its not updated in grass webpage. I will ask Markus Netler who has can update this page [1]
[1] http://grass.osgeo.org/download/software/linux/
On Wed, Sep 4, 2013 at 11:48 AM, Johannes Radinger <johannesradinger@gmail.com> wrote:
Thank you for the quick reply…
so just to be sure:
the grass70 is now located at GRASS GIS PPA.
the actual stable grass64 (643) is still located in UbuntuGIS-unstable PPA
or also maintained for GRASS GIS PPA?
/Johannes
Rashad
On Wed, Sep 4, 2013 at 11:28 AM, Rashad M <rashadkm@gmail.com> wrote:
you can check grass PPA in ubuntu. I am not adding grass70 to ubuntugis-testing PPA because its getting deleted a lot of time. GRASS GIS PPA has daily builds for grass70 for raring and quantal. You can see details here - https://launchpad.net/~grass/+archive/grass-devel
On Wed, Sep 4, 2013 at 11:15 AM, Johannes Radinger <johannesradinger@gmail.com> wrote:
Hi Rashad,
I just checked the link that is provided here: http://grass.osgeo.org/download/software/linux/
which points to the ubuntugis-testing repository
for downloading a precompiled GRASS70 package.
However, this repo does not include GRASS70.
Is there any way resp. any repo that contains already
an actual version of GRASS70 for Ubuntu or do
I have to compile it myself?
Usually I compile it myself but now I just set up a
very slim Xubuntu on a virtual machine for a collegue
and wanted just to simply install GRASS70. Any pointer?
Rashad
