[GRASS-dev] grep -E?
[I'm extending v.in.garmin to work with gardump from Snafu's garmin-utils]
can we expect 'grep -E' to work everywhere grep works? (aka egrep)
ie is -E portable or a GNU extension? I want to use the '|' infix operator.
Hamish
Just use basic syntax and use \| instead of | .
Having said that, I'm fairly sure that both "grep -E" and "egrep" are
portable.
